Liked 816 Times in 215 Posts
I had a blow out yesterday coming home from W. Lebanon.
Can anyone steer me in the right direction on buying trailer tires. I have a 24' Enclosed w/ 15 inch rims. I want to know which tires to avoid ( if anybody had bad experience's with ) and which tires to buy. Any information is Greatly Appreciated.... I do not want to be changing a flat in 95 degree heat if i don't have to. Thx for any input. Pistol Pete 1374- Stock |
#2 | |
Pete, do you have 6 lug wheels? If you do, I would suggest getting 16. in wheels and tires. I made the mistake and bought new 15 in.tires, still had problems, then ended up replacing the wheels and tires a couple years later. Well worth the peace of mind.
Joe Martens AA/Stock 3969 |
Liked 56 Times in 27 Posts
Pete,
If you plan on keeping the Trailer, find some 5 lug 16" wheels that fit and go to 16" tires which gives you better choices of tires .. If you don't change to 16", then carry extra spares and check them every-trip ???? LOL,
Dave Ribeiro 1033 STK |
Liked 100 Times in 45 Posts
I've used Goodyear Marathons for the past 10 years.I left the first set on too long,unintentionally,and it almost bit me in the *****.A few things I do is keep tire dressing on them(especially the ft. mounted spare under a cover,50 psi in them and I keep them covered when the trailer is not moving.I've never had an incident,luckily.If you want the absolute best 15" tires go to either tires-easy.com or tire rack.com and look up 15" Maxxus trailer tires.A bit pricier than Goodyears but I understand they are the best you can get in a 15" tire.And keep after them.Also whatever tire you buy look at the date code on the sidewall.More than a year old and I don't accept them.
Former NHRA #1945 Former IHRA #1945 T/SA |
Liked 886 Times in 238 Posts
Pete, all good recomendations ,but the most important one is to make sure to use metal valve stems on your rims. ..........the rubber valve stems can fail or loose air pressure that can cause a tire failure. ............One of the reasons we're not allowed to use them on our race cars!............A good friend ,who is a tire dealer and outfits several heavy concession trailers that log way more miles a year than we do , recommended Hankook tires to me....I've had them on for about 35k miles now ,never a problem , and great wear. .........Tom
#7 | |
This is what you will get. You will get a 6 lug hub, a larger outside bearing, and peace of mind that your trailer won't give you any more problems. Not many people realize that this is a perfect fit to the old set up that you have. The larger tire will roll better and won't blow out like the weak 15" offerings. The outside bearing may not be giving you trouble now, but it certainly won't with the 7,000 lb version. You can really make it bullet proof with the "G" rated Goodyear trailer tires that will allow you to tow at more than 65 mph. |
This comes up about once a year, usually in the summer heat.
The best 15" tire I've found is the Maxxus load range E, fill to 90 lbs. Heat is what kills trailer tires and high pressure goes a long way to stopping that. I second the steel valve stems also. That being said, I think Fletcher posted on here once that the worst 16" tire is better than the best 15" and who puts on more miles than Dan? I'd listen to him.
John Mason 7743 SS |
Now there are a lot of good recomendations from people that race quite a bit.
ED: What do you mean, "keep after them". By putting dressing on them or what ??? I did have another gentleman tell me about Maxxus, so i think i'm going to look into those. TOM: Thx for the tip about the metal valve stems, i wouldn't have known that. Everyone else that commented, thank you for steering me in the right direction. BTW, my trailer does have a 6 bolt pattern & I only race locally anyway which means no more than a 2 hour tow, so hopefully i won't have to get the 16" rims. OK so no more blow-outs for me....lol Thx Everyone..... Pistol Pete |
One More Thing.
Is there any Pro's & Con's to Carlisle Trailer Tires ?????? Thx |
