#1 | |
Jerry Williams NSS/A, E/S, PRO E.T. And the "Grandaddy" of Gen III Hemi Performance...The fire inside me still burn's. |
Liked 100 Times in 45 Posts
I suggested that after the accident at Englishtown and was told it was stupid and too expensive/impractical.I still think it can be done.Someone said all the tracks couldn't comply.They don't have to,the Safety Safari crew can set up and operate the system,which would have to be designed to be adjusted to stop the full range of cars in compitition.
The cost,in the long run,would probably be cheaper than making the insurance company rich.
Former NHRA #1945 Former IHRA #1945 T/SA |
#3 | |
An F-18 weighs around 35,000 lbs on final approach to hit the deck and the speed is around 145~155 mph. A dragster or funny car is much lighter with terminal speeds exceeding 260 mph. A heavy fighter airplane can run over the cables on the deck and the landing gear squawk switch will deploy the hook automatically. A lightweight race car at high speeds running over the cables would be propelled off the ground and loose control and would also require the driver to deploy a hook manually. One problem with sand traps is when the sand gets wet, it will compact creating a hard surface. A better solution would be substitution of the sand with small gravel the same way they do with highway sections that have runaway truck provisions. |
We are sorry to hear of the death on Mr Niver.
http://www.competitionplus.com/index...atally-injured Watching the video of the accident, the car folded over on itself when it hit the netting and it didnt look as bad as it was. These things are happening way too much and something HAS to be done,I just dont know what. Its not just the Pro cars having problems. We had a twin turbo Outlaw car have the parachute malfunction here at SAR a few weeks ago.Car went through at a high 6.XX @ 210 plus and when the chutes were deployed the cm cross member they attached to broke in half and the mounting loops slid off of it. He went off the end and totaled the car,he suffered a compound fracture to his ankle(foot still on the brake pedal trying to slow down we believe)and other injuries.
First On Race Day Last edited by smracer2002; 07-13-2010 at 09:23 AM. |
the catch nets need to flex and slow the car down......not 2 steel cable tied to posts instant stop no give.....
How about the cable on pulleys that are tied to weights that gradually catch and slow down as the car goes in to the next catch net same system? The way the system is now I think I would rather scrub against the wall and go sideways in to the net. |
I agree with SSDiv6. My dad has been a truck driver for forty years, and once had go into one of those runaway truck ramps when the brakes failed. They are made of pea gravel. When he stopped, about halfway up, he was buried up to the axle in gravel. Now, granted, a 80,000 pound semi will probably sink better going 70-80 mph than a 2,000-2,400 pound dragster/funny car at much higher speeds, but might be worth a shot.
Mike Carr, Tri-State S/SS Association President Looking for 2015 S/SS Race Sponsors Contact me if interested buffdaddy_1302@hotmail.com (724) 510-5912 |
#7 | |
posted on another site by a Seattle worker.
First On Race Day Last edited by smracer2002; 07-13-2010 at 11:07 AM. |
#8 | |
Liked 1,928 Times in 434 Posts
Alan Roehrich 212A G/S |
Liked 293 Times in 65 Posts
What about some form of this system: http://en.wikipedia.org/wiki/SAFER_barrier ?
Maybe rows of them instead of sand? |
Liked 53 Times in 13 Posts
N H R A must look at formula 1 and how the BRAKES are on those cars and the tub around the driver. those brakes can stop the formula 1 car at 220 mph, it can stop an
alcohol dragster/funny car and for that matter a nitro car and even pro stock. The brakes on the PRO / alcohol category cars are a JOKE compare to formula 1. Jeff Gordon drove a formula 1 car a couple of years ago and he said what is more incredible than the excelaration is the braking on the car. Luke SS 311 |
