Old 07-20-2010, 05:18 PM   #12
moparwedge6
Default Re: Mopar To Release Lost A-Body 1/4 Mile Test Results
Myron
Yes Chrysler Did alotta Testing with a74 360 Duster, that Eventually End up with a Tunnel ram 440 S,g style and It Was called "The Red car"it Burned up Bad in the Late 70s when Testing The Gold Box ecu. Also Paul Adjusted Tire Pressures would have Been 35 to 40 lbs as the Tires Were Polyglas And the Work Better with Higher Pressure.How i know This Cause i was Parts Guru at one Of The Biggest Dc dealers in the Country.Did a Few Clinics with Larry sheppard when the Came out West. Jeff Lee i can rember when the "BIBLE" was available in indivual Booklets 1.00 apiece Tune Up Tips they were called.
I had chevy racers Buyin the" Bracket Racer Science".Mopar had the Best Performance stuff around.Stuff was cheap and it worked.
moparwedge6 is offline   Reply With Quote
