Old 07-21-2010, 02:35 PM   #11
Eric Kitzan
Eric Kitzan's Avatar
Default Re: Ford Stocker idea?
Thanks for the info guys. I told him to race a Chevy
Eric Kitzan
66 Chevelle Malibu Wagon
Stocker
Eric Kitzan is offline   Reply With Quote
Old 07-22-2010, 05:19 AM   #12
Chris1529
Liked 70 Times in 29 Posts
Now theres an original idea! lol!
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 07-22-2010, 07:34 AM   #13
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Originally Posted by John Quinn View Post
The Falcon never had a 4bbl V8 option. Mustang, Fairlane, and Comet all had 4bbl.
What about the '67? I think it is listed in the CG with a 289-225. And the '68 had the 302-230 combo as an option. I know those are not the body style being questioned, but they are Falcons.
Old 07-22-2010, 09:57 AM   #14
John Quinn
As you pointed out, they are not the body being discussed. But (and I quote from the Falcon Fairlane Club) "From 1966 to 1970 the Falcon became almost a forgotten car."
Obviously I forgot it.
Stock - 5013
John Quinn is offline   Reply With Quote
Old 07-22-2010, 11:46 AM   #15
Jeff Lee
Jeff Lee's Avatar
Somebody that loves their Fords needs to petition NHRA for a much smaller HP factor on the 289/271. I'm just shootin' from the hip but I'll bet 250 or so would be more appropriate as a starting point. It's basically a high compression larger cam & slightly better intake than the 289/225, right? Ports are the same and the screw in studs are not a bonus anymore. Neither is the solid lifter cam in todays world.
Jeff Lee 7494 D/S '70 AMX
Old 07-22-2010, 12:49 PM   #16
John Quinn
Slightly more compression, better cam, bigger carb. Same intake. It would be hard to find the right iron heads but the aluminum replacements are available in SS.
Which leads me to a question, is anybody using the aluminum heads on a 289?
Stock - 5013
Old 07-22-2010, 01:21 PM   #17
Fred Holdorf
Jeff & John, From memory we had trouble making power from the 271 HP (HI-Po) heads back in the day, due to the heart shaped chambers. Ford used them to up the compression. They shrouded the stock sized valves and we found more power in standard heads with big valves. You are correct all the SBF heads, I saw had the same size ports. There were some expiremental heads that Doug Nash, on his Bronco Funny Car, ran that he could not talk about. Old mother Ford helping us little guys, NOT!
Fred
P.S. These are from my observations back in 1963 to 68.
Fred Holdorf is offline   Reply With Quote
Old 07-22-2010, 01:35 PM   #18
John Quinn
What really heats my motor is that Ford developed the "GT" head in the 60's and never released them until the 93 Cobra Mustang. All us small block lovers could really have used them but Ford's attitude was racers all want big blocks.
Stock - 5013
Old 07-23-2010, 07:31 PM   #19
Pat Cook
According to the NHRA engine classification guide, 68 Falcon/Mustang was available with a 4 barrel and 10.1 compression, with little bitty valves and a small camshaft.
Anybody traveling between Las Vegas and Phoenix Az, there is a real nice 68 V8 Falcon sitting in Wickenburg along the east side of 93. I have been going to stop and see it is for sale, but as usually always running late
67 Ford Fairlane
F/SA
749
Pat Cook is offline   Reply With Quote
Old 07-24-2010, 09:17 PM   #20
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
are you interested in a factory 1965 289 bored .040 w forged TRW pistons part number L3096 F. factory 4 barrel cat iron intake w a hydraulic cam. 5C8 date code heads block and intake, its numbers match. Its a hydraulic flat tappet motor. never fired. on stand. trying to help you get started and help me with my projects. Chris.
Last edited by chris ok; 07-24-2010 at 09:18 PM. Reason: forgot piston part numbers. Chris
chris ok is offline   Reply With Quote
