#11 |
Liked 880 Times in 311 Posts
That 402 is a good combo. You need to be sure to read the blueprint specs on it real close. It has some numbers that are a little different, too. ;~) OK Mark and Alan... I didn't spill the beans on this one... HA!
Adger Smith (Former SS) |
#12 |
Liked 20 Times in 9 Posts
compcam has a spec stocker 396 375 horse cam in there catalog,it may give you some idea.You can also goggle it.
#13 | |
Liked 1,830 Times in 415 Posts
Even if you want to build it yourself, you need to establish a relationship with a good builder, so that you get good parts, and don't waste your time and money doing it wrong. The learning curve in Stock is STEEP and real mistakes get extremely expensive and frustrating. Stock Eliminator stuff absolutely cannot be taken just anywhere. It has to be done by machinists that know exactly what they're doing, the attention to every minute detail is what makes the difference between a good piece and a slug that will not stay together.
Alan Roehrich 212A G/S |
#14 | |
Bub Whitaker |
#15 |
If you do not know the actual cylinder head air flow numbers of whatever engine it is you want to build, then as far as the cam specifications it's GARBAGE IN / GARBAGE OUT.
What that also means is you might want to choose the engine first, cylinder head casting number second, then have all the work done to the heads, then make sure your intake is up to snuff, then determine what your piston to valve clearance is so you can maximize those numbers with the cam. It should seem obvious that asking for cam specs or anything related to a part number is something you are way far away from. Right? For now, all you really should care about is what the lift is per NHRA and how that should relate to the rest of the engine selection. There's more but as Mark said, this is no silver platter club!
Jeff Lee 7494 D/S '70 AMX |
#16 |
And Bub is just one of the guys I was talking about. Bub would be the guy to talk to if you're in his area, John. In the Carolinas, you have Arnold Greene and Mike Heintz. In the mid west, you've got Darrell Wikle. In Texas, there's Adger Smith. Up around the Dakotas, you have Steve Koppien. And out there on the left coast, you've got Gary McGlasson. Here in my area, you've got Jimmy Bridges and Kenny Schindler. Down south, you've got Woodro Josey, if you can con him out of retirement. Those are just a few, and several of them have helped me a ton.
#17 |
Liked 705 Times in 219 Posts
I think that if I were starting over in a whole new area, or building a car from scratch again, I would buy a car I liked, learn it, refine it, learn to drive it, and figure what it likes. This person is interested in a high maintenance combination, and I probably would start out by locating and buying a good used stocker motor, learning how to tune it, drive it,etc. and that would save me a lot of time and money on that end of the learning curve.Building a whole new car from scratch is so much work, and a lack of experience at that point usually means that a lot of it gets done again with different new parts over and over again.It might behoove a new racer to think of that rather than look for castings, a machinist, a trustable source of information, and a whole lot of things. At any rate, welcome to the Stock Eliminator family, and don't get discouraged too soon.
#18 |
Greg, I don't disagree with that at all. Were it not for the fact that he said he's built the body and chassis already, I'd tell him to go look for a car he likes and buy it. And he'd probably still be better off to buy a good used engine, but he wants to build his own. And he may be needing to spend a little, save up, and spend a little, several times, to afford it. In that case, he's better off doing what he can afford as he can afford it.
One thing a lot of us forget is that one reason people build a car instead of buying one is that it allows them to spend money over time, rather than trying to save that money and spend it all at once. Something always seems to come up when you're trying to save up. There's always a need for that money you have put back.
#19 |
#20 |
Liked 5 Times in 3 Posts
Black magic & shell games is all it is.......how else would an 86 Camaro go 10.83 with a "stock" 305????? ( that was a long time ago though)
