Art, have you tried with a 16V?
I have a new "Performance V" 16V but as my car is under construction, I can't comment on battery voltage life. My research was that it would take a lot of runs to get down to 12V and I checked all the amps my car was using and one 16V was more than ample. The fact I have a 4-speed helps as I don't have all those driver aides with an auto trans which use up a lot of energy!
Jeff Lee 7494 D/S '70 AMX |
Jeff I haven't tried the 16 volt system. It might be enough. I could eliminate some of the current draw, My fuel pump is total overkill (think thats where most of the ET is).
There are a few other things I want to do first. Real intake manifold. And a final drive ratio better than 3.73
Art Leong 2095 SS |
The '87 Shelby Daytona Z I raced in A/FS had a factory Getrag 5 speed with 3.91 ratio. As I recall, with 20" slicks it went through the lights somewhere around 6200 in 4th . Yours is a stick isn't it?
No both Tim and I run an auto. I'm just starting to get in my powerband at 6200 I cross the line at about 6400 at 105 mph. Still using the 20" slicks
Art Leong 2095 SS |
I use the ROCK 16v with no alternator. Great piece. 1-910-582-3400
Liked 4,384 Times in 504 Posts
I use powermaster XS 16v battery with no alternator.. I haven't had an issue yet and I can definitely go 2 rounds without charging but I usually put the charger on after each round. Don't forget you need a 16v charger for that. I can say that at tracks like Englishtown (or any other track where you can't roll down the staging lanes) where you start your car roughly 20-25 times from when you leave the trailer til you return it still cranks great after each run. Also, your starter cranks like 100mph faster you'll hear it! As far as power gains, they say the spark is hotter but I built a new motor this year so I'm not sure about that.
#7 | |
Liked 5 Times in 5 Posts
