Old 08-24-2010, 06:14 PM   #1
dragginwagon
Default chevy wagon powerglides
...are powerglides from b-body wagons different from the sedan coupe offerings...ratios? coolers?
dragginwagon is offline   Reply With Quote
Old 08-24-2010, 06:49 PM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: chevy wagon powerglides
Dragin,
to my knowledge GM only built two ratios. 1.76 or 1.82. Generally, smaller engines used the 1.82 and larger engines used the 1.76. But you could find just the opposite of that in some combinations.
In addition, as the powerglide equipped car aged and the trans were overhauled, sometimes more than once during the service life of the unit, changes were often made or used trans installed, etc.
So just because you find a certain trans in a certain car it has a reasonable chance of not being the original setup.
There were some minor internal differences through the years. One of the best reference manuals about selecting parts & building the powerglide is the Carl Munroe book.
http://www.amazon.com/Powerglide-Tra...2695751&sr=1-3
Old 08-24-2010, 06:53 PM   #3
dragginwagon
thanx...car is a 67 Impala 275 hp 327 and has original powerglide...
Old 08-24-2010, 07:14 PM   #4
Dragsinger
In that instance it is most likely a 1.76 low with a 5 clutch pack high gear. It will be worth tearing down and checking. If it is in good shape most of the internal hard parts will be fine for a race build up.
I do highly recommend you buying the Carl Munroe book to help with your powerglide parts knowledge.
Old 08-24-2010, 08:15 PM   #5
dragginwagon
thanx...will track down that info...
Old 08-24-2010, 08:59 PM   #6
Bob Verwold
Bob Verwold's Avatar
Just pull out the input shaft. The 1.76 is 12 7/8" and the 1.82 is 12 5/8" long.
Bob Verwold is offline   Reply With Quote
