Old 08-26-2010, 03:54 AM   #1
Barney B
Barney B's Avatar
Default Re: t stop thoughts/debate
Originally Posted by sc7667 View Post
This was suggested to me by Sherman Adcock about 10 years ago. I trusted what he said as he had won a supergas championship. One of my cars is a 160mph car but the other I drove for a few years is a 175mph car and it is set at 4000rpm and I only have 2-2.5 in the timer. I do know a couple of high mph cars that set their stops at 4000 and have about 3 seconds, these are 180+ mph cars that have tried lower without success. There are always acceptions to the rule. There are also other factors in your setup that can effect this working or not like shift time, tire and gears.
I was joking he is a friend and team mate. My combo is; .10 first timer and anywhere from 1.6 to 1.9 on the second timer, shift at .70 out. I play back ever run and my dead stall is 4100 rpm give or take 50 rpm's.
I go anywhere between 168 to 171 @ 8.90 on the stop.
BB
Barney B is offline   Reply With Quote
Old 08-26-2010, 11:58 AM   #2
sc7667
BB
Cool, he really set me on the right path. I was young, dumb and struggling to get my car to work on a t-stop. He was at a George Howard big money race in Tucson as a guest speaker and came to my pit and talked to me for a good half hour about throttle stop theory.
My uncle's car, that I drove for a couple of years, is very similar to that setup. Same RPM similar shift and on tmer for 2.25 to 2.5 depending on track elevation 171-175mph. One of the most cosntent cars i have seen, but liked to throw out a 4 hundredths slow run once a weekend, usually in eliminations.
sc7667 is offline   Reply With Quote
Old 08-26-2010, 01:10 PM   #3
Ed Swearingen
Ed Swearingen's Avatar
Send a message via AIM to Ed Swearingen
Y'all know my thoughts on the subject! Get rid of all those big motors and get "Adjustaflows". It's been working for me since '84.
Ed Swearingen is offline   Reply With Quote
Old 08-26-2010, 04:55 PM   #4
Bill Baer
Careful Ed, you'll piss a lot of people off with that kind of heresy!
L.O.L.
Old 08-26-2010, 10:52 PM   #5
sst7250
sst7250's Avatar
Liked 45 Times in 32 Posts
With the car set up with a lower down power number I have been 159 and change at 10.90 a number of times. All out the car has been 168. I wish I could find a good set up to not loose the MPH I do. But the car is not dialable(is that a word)set up that way ,at least for me but it can go 159 at 10.90. One thing for sure in Phoenix my t stop set up was NOT the way to be doing it on that track that weekend. Last S/ST race I ran at Infineon the car was running 153-4 with over 5 seconds in the timer. DA's were -50 to 600' IIRC. Hard to run fast when I am on the stop at 4100 that long. So tell me please what the secrect is. I have watched your car a ton of times trying to figure out that magic set up Give me a break that Infineon Divisional was my FIRST ever S/ST race. Thought I did ok we are still trying to figure this stuff out for sure.
Cant keep it running that that long, TOUCHE! Jeff you got me there for sure. The again I dont have anywhere near the cubes at 500" that some do. Motor had 228 passes on it when we pulled it out. About 1/2 wide open shifting at 8300, but only going through the traps at 7450(no gear). Had a freak failure for sure. The Roller that was in it went soft, I run a roller cam bearing and one of those bearing surfaces on the cam was flaking. Scored cylinder walls and was wreaking havoc in general. Last time the car was out was on Memorial Day at Infineon with the cam going south I went 11.04 at 152 with timer one at .000 and timer two at 4.87. The next pass was more of the same and the car should have been faster. Did some poking around and decided to just put it away and freshen it up to try and make the infieon race. Well we pulled the motor down then and just now getting it back in the car. I simple freshen up ended up being a reinvention after finding the roller cam had gone soft on one of the bearing journals. So new pistons, to address a longevity issue, this motor was from a heads up small tire car and never really set up for a ton of laps. We added some more material under the pin, new rods, and a new cam, rings and bearings. Hopefully we did not give up to much power with a new piston that is heavier but for longevities sake it is the right thing to do. Biggest issue was the cam, kept me out of the fun all summer. Trying to get/find a core when you run a 55MM cam, ina Big Block Mopar, that has a 4/7 swap AND all 5 journals being 55MM is not easy to do. So we will see what it will run son enough. We seem to think that the piston deal is gonna cost some power but not sure how that will translate to MPH on track. If I can get off the stop sooner it SHOULD go faster maybe, but time will tell.
Can I help if I like to go fast? Wish I could figure out how to go as fast as that Mustang can, I think I do ok for a 2885lb Super Streeter. Then again maybe I should go back heads up small tire racing. Can always dust that thing off and go run 7's all day long....
sst7250 is offline   Reply With Quote
