Old 09-03-2010, 04:25 PM   #1
j holston
Default Re: higher staging rpm stall speed= reduction in R/T
Stall speed will change your R/Ts but every car is different, my bracket car changes about .010 for every 200 rpm change. There are some different ways to change your R/Ts if the stall speed dont work for you or your car. You can adjust front and rear tire pressures or adjust the travel in your front end, if you tighten your front up it will make your R/Ts quicker but you will be more likely to have traction problems. Its all in finding what works for you and your car.
j holston is offline   Reply With Quote
