Old 09-08-2010, 12:06 PM   #1
L78 Nova
L78 Nova's Avatar
Liked 23 Times in 13 Posts
Default Re: Battery Shut Off
My thinking was... trying to get away from the large gauge "hot" lead all the way to the back. The alternator then has to charge through that entire length The main harness power feed (on horn relay) would also no longer be fed direct from the alternator so all running load would draw entirely through the starter feed (rather than paralleled with the alternator feed).
I did blow my regulator once already with the single pole cut off.
Thanks for your input, I will check at yellow bullet also.
L78 Nova is offline   Reply With Quote
