Old 09-09-2010, 11:45 PM   #1
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Pinion preload for Ford 8.8 stick car.
With new bearings is having the pinion preload at 12-15 in/lbs too light? This is without the seal installed yet, and a solid spacer. 25 in/lbs is what is recommended for a street gear with new bearings. Any thoughts or recommendations would be appreciated.
Thanks
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 09-10-2010, 04:43 AM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: Pinion preload for Ford 8.8 stick car.
Sean,
my method for the pinion is to have almost no preload, just barely have the slack out. Never any problem in a wide range of applications and performance levels.
The side bearings will have slightly more preload, the shims will require a light, tap. tap, tap to install.
When completely assembled the gear set will be very easy to rotate.
Old 09-10-2010, 05:27 AM   #3
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
What Dragsinger said, if want to measure most rears factory spec is around 40'' lbs.
I usually go by feel like dragsinger a good example is have slight drag like front wheel does,as long as you have enough preload that you have no slack up& down you should be fine.
Mike Taylor 3601
Old 09-10-2010, 07:54 AM   #4
Sean Marconette
Thank you, Dragsinger, and Mike.
I am glad I asked.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 09-10-2010, 08:45 AM   #5
buzzinhalfdozen
Liked 11 Times in 8 Posts
!2-15 inch lbs. is fine you absolutely have to have SOME preload on the bearings, without it the pinion is free to move. I try to get 20-35 in. lbs total turning torque on race rears. Joe
Joe Buchanan SS/BX 3117
Old 09-10-2010, 11:19 AM   #6
You won't have to worry,Sean. After a few launches with a stick car,it'll be loose anyway
Old 09-11-2010, 10:15 AM   #7
Sean Marconette
Thanks Joe and Mark. Its done and back in the car.
Much better than what I saw with the gear set I replaced. All of the pinion teeth had stress fractures and were ready to let go!
Sean
Sean Marconette
84 Mustang
5060 SS/N
