Old 09-10-2010, 10:54 PM   #1
Knocky
Default Re: Q jet Question
Mark, If using the big needle and seat (I think it is 0.135") in your q-jet, try running no more than 4-5 psi max, the float bowl will stay full. Higher psi never worked well on my 455 Pontiac either.
MWNorris
Knocky is offline   Reply With Quote
Old 09-10-2010, 11:20 PM   #2
Dave Ribeiro
Liked 56 Times in 27 Posts
Wink Re: Q jet Question
Mark,
I would try another gauge, if you can't find one , turn the pressure down to 4 lbs and see how that runs & feels ? If it works , it may get you by for this weekend .... If it doesn't work, adjust in 1/2 lb increments till it get better... Could try another carb ? Also , try ; turning on the pump & look down into carb to see if it's bleeding over with too much pressure ? ........... Good Luck .........
Dave Ribeiro 1033 STK
Old 09-24-2010, 07:32 PM   #3
Mark Callanan
Liked 64 Times in 14 Posts
Originally Posted by Dave Ribeiro View Post
Mark,
David
Good call the gauge was bad
Mark Callanan 1027 STK
Mark Callanan is offline   Reply With Quote
Old 09-25-2010, 10:32 AM   #4
Dave Ribeiro
Cool Re: Q jet Question
Mark,
Glad you found your problem & congrats on your Win @ the Last IHRA event at NED ....
