Liked 56 Times in 27 Posts
Mark,
I would try another gauge, if you can't find one , turn the pressure down to 4 lbs and see how that runs & feels ? If it works , it may get you by for this weekend .... If it doesn't work, adjust in 1/2 lb increments till it get better... Could try another carb ? Also , try ; turning on the pump & look down into carb to see if it's bleeding over with too much pressure ? ........... Good Luck .........
Dave Ribeiro 1033 STK |
#2 | |
Liked 64 Times in 14 Posts
Good call the gauge was bad
Mark Callanan 1027 STK |
Mark,
Glad you found your problem & congrats on your Win @ the Last IHRA event at NED ....
