Old 09-15-2010, 10:32 AM   #1
Chad Rhodes
Default Re: Drag Pak/Cobra Jet FX classes
Originally Posted by dwydendorf View Post
You guys are assuming that there hasn't been any R&D done on these cars but you couldn't be further from the truth. Did you honestly beleive that a magic fairy appeared and instantly made these cars fast? The horsepower factors have contributed to the cars going fast but there is more to it than that. If The people buying these cars and the oems have the money don't you think they have access to the same companies that make the products in your race car? You might be surprised at the list of racers who have contributed to the success of these cars.
the magic fairy is bolted to the intake on the CJ's, in case you didn't notice. At least it requres some skill other than writing a check to go fast with a DP
Chad Rhodes 2113 I/SA
Old 09-15-2010, 11:26 AM   #2
SSDiv6
There is a lot more in the CJ's that makes them fast than the supercharger.
That "Magic Fairy" has been bolted not only in the CJ's, but also in a lot of other of other OEM cars including Japanese, European and US cars, including GM.
For starters, you have a OHC engine with very efficient cylinder heads. Then add what is called in the automotive industry, Displacement on Demand (DoD) Systems.
The DoD technology enables the Engine Control Module (ECM) uses the information related to the operational status of the engine to implement real-time running efficiency of the engine and effects changes in the operation of the engine through the control systems that manage its operation.
I do not know if the these cars are using Variable Cam Timing (VCT) and/or Variable Valve Timing (VVT) like the new Ford 5.0 engine does. I have seen the ECM graphical displays for VCT and VVT and I can tell you you can program the cam events for maximum engine efficiency throughout the whole run.
If the next generation of CJ's have the new 5.0 engine, as proposed, with ECM controlled VCT and VVT, watch out.
Old 09-15-2010, 11:42 AM   #3
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Angry Re: Drag Pak/Cobra Jet FX classes
More reasons to put them in their own class OR add a ton of HP to the factor.
Old 09-15-2010, 11:43 AM   #4
GUMP
Liked 2,361 Times in 558 Posts
You are old enough to remember when they had to run the factory exhaust!
Old 09-15-2010, 11:50 AM   #5
X-TECH MAN
Banned
Talking Re: Drag Pak/Cobra Jet FX classes
OUCH ! but yes I do.
Old 09-15-2010, 12:09 PM   #6
Chad Rhodes
I beg to differ. A naturally aspirate mod motor from ford (aside from the new 5.0) is best suited for use as a boat anchor. They are bloated, oversize, overweight (as big as a hemi), and don't run worth a crap without forced induction. Why do you think the "crate" CJ's are windsor base?
You are correct about the VVT/VCT, although DOD will have no affect on a race motor. If they are allowed to run VVT/VCT it will open a bigger can of worms than EFI did when it first came on the scene.
Old 09-15-2010, 01:03 PM   #7
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Terry you old fart ! Yea but they were not hooked to the hedders, they just hung there.
Bob Pagano A/SA
