Old 09-19-2010, 08:55 AM   #1
Todd Boyer
Liked 6 Times in 5 Posts
Default Re: Lead shot for ballast bars
A friend did the wheel weight thing. He melted the weights down and seperated the steel clips then poured the molten lead into steel 2x3 tubing. Stinkin' things are HEAVY too !!!
Old 09-19-2010, 12:46 PM   #2
Philip Saran
Liked 14 Times in 11 Posts
Along time ago (1980's) I made my own lead weights for the
weight box. Got scrap lead from my brother-in-law (my former
boss @ scrap metal yard) and melted it in a cast iron frying pan
over a propane camp stove and poured into molds I had made.
Probably not the safest way to do it in hinsight.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 09-19-2010, 01:10 PM   #3
SuperStock 1890
SuperStock 1890's Avatar
I went to one of my lift truck battery suppliers and they have a heater for lead that they use in the making and repairing of batteries. They filled a bar up for me. Much safer.
You don't know what you don't know yet.
SuperStock 1890 is offline   Reply With Quote
Old 09-19-2010, 01:11 PM   #4
GUMP
Liked 2,361 Times in 558 Posts
I buy buckets full of weight from a local tire store for $25.00. I cut the ends of the longer weights and drop them into square tubing with a cap welded on one end. I then use a torch to heat the tube. As the weights melt I drop more in until the bar is full. Finally I weld another cap on the top to enclose the lead.
Old 09-19-2010, 04:24 PM   #5
sscrewcheif
sscrewcheif's Avatar
Send a message via Yahoo to sscrewcheif
we have purchased lead from a roofing company...they use it for flashing. melts easy and makes good bars.
Big wheelies are for show!!
Go fast or go home!!!
sscrewcheif is offline   Reply With Quote
Old 09-20-2010, 01:23 AM   #6
James L Miller
Liked 25 Times in 16 Posts
I've thought about using zinc anodes for boat hulls. They come in plates and various sizes. Here's a sample:
http://www.zincboatanodes.com/hull-z...te-anodes.html
Mopar 2 Ya!
Old 09-20-2010, 04:10 PM   #7
treessavoy
Liked 4 Times in 4 Posts
I used to get the wheel weights, melt them down, pull the metal out, pour them into a Chevy small block valve cover and inset 5/8th's bolts in them, once cooled you just pry them out of the valve cover and the are ready to bolt anywhere using the threaded ends of the exposed bolt.
JimR
Jim Rountree
Old 09-20-2010, 05:42 PM   #8
Tom Simon
The last time I made up lead for my car, I bought some lead plate from a local metal salvager. I called around and happened on a guy who happened to have a ton of excess new lead 1" thick plate. He even sawed it to size on his plate saw for me, and delivered it.
I've dealt with weight tubes and lead shot, after one spill I didn't want to go with shot again.
Depending on how much you need, 1018 steel plate is a cheap, easy to get option, especially if you live away from an industrial area... and if you care about toxic, it's pretty inert, easy to cut up into usable chunks.
Unlike depleted uranium counterweights used in some aircraft, we don't have the most dense metal available to fit in some confined space
I imagine more and more racers will be getting away from lead all together. Salvaged steel plate can often be had for less than 25cents/pound and weighs 70% of lead (lead is .4 lbs/cu inch, steel is .284 lbs/cu inch)
I'm not sure where us civilians would get depleted uranium, but at a dense .7lbs/cu inch, it's no wonder the the stuff has found its way onto the battlefield
Tom Simon is offline   Reply With Quote
Old 09-21-2010, 04:37 PM   #9
Rob Petrie E395
Liked 216 Times in 77 Posts
I went to a local handgun range and offered to sweep up the bullets at the target end if they would let me buy some. They brought me out a bucket on a hand cart and said take all you want no need to sweep thanks for taking them. They are not all the same size but if you are melting them down or putting them in a box or tube nobody would ever know and its a whole lot cheaper than buying lead shot at the sporting goods store.
Old 09-22-2010, 11:53 AM   #10
sscrewcheif
Very good idea.
We where fortunate enough to find a guy that was retiring from making fishing lures and acquired all his surplus lead. I came in the form of small bread loafs approx. 28 - 30 lbs. each
