Old 09-20-2010, 06:53 PM   #1
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
Default Re: question for buick boys!
I just sold ours, no girdle nothing special speed pro motor, it liked 32-34. It did not like a square lobe cam!!!!! Get a easy smoooooooth ramp. 6500 max rpm
72 cutlass
Daran Summerton is offline   Reply With Quote
Old 09-20-2010, 09:19 PM   #2
SSGN
SSGN's Avatar
Liked 180 Times in 52 Posts
Cool Re: question for buick boys!
Send a PM to Tom Rix he is always more than willing to help Buick guys out.He ran a Buick in Top Stock and it was very competitive in the first season.Good luck and welcome to the dark side LOL
Kevin
Old 09-21-2010, 03:27 AM   #3
rowdyboys31
Mike I have raced 455 for a few years(lol) and have run the 350 the last year and half because the 350 make's alittle more hp per cubic in. I just got a new cam for the 455 and should have the 455 back in car soon. Ok back to your question, I run 38 or 39 degrees of timing. I use the MSD Dist. with all timing in at 3000 rpm in both motor combo's. The reason your stock 455 motor has a 5000rpm range is valve float from lifter preload (AKA) pushrods down in the lifter . I do not run any studs or girdle's for crank or valvetrain, RPM wise I spin my motor's in 5800 to 6400 rpm with 4.10 or 4.30 ring& pinion. Hope this help's you out, If I can help in any other problems e-mail me your questions at rowdyboys@comcast.net JOHN KEIHN 3954 G/sa-K/sa
rowdyboys31 is offline   Reply With Quote
Old 09-21-2010, 09:32 AM   #4
Dean3870
Thanks for all the help guys, I had talked to Bill Baker last night, and he told me the same thing, dont realy need the main cap gerdal! said make sure the oiling system was perfect and shouldent have much problems! What about this core shift i keep reading about? Is this a big problem for our motors? And is bullet the place to call for a buick stocker cam?
Im gona try to get the carb out to Mike Walter soon if i can, to get fresh. And am still trying to find a machine shop around my area that i trust with a buick motor!
Once again, thanks for the help guys, and have a great day
Mike Dean
G/SA 3870
Dean3870 is offline   Reply With Quote
Old 09-21-2010, 10:20 AM   #5
Johnny U
Thumbs up Re: question for buick boys!
Dean the Baker boys are good people to talk to. They bleed Buick red. As far as main cap girdle not necessary, if you are starting a build find a later block, 75 or 76 as I found they seem to be the better ones. I used a 75 motor for my SS motor and after 220 runs on the short block all seem o.k. I spin the motor to 6600 through the traps but have tried as high as 7000 rpm. I should be in Columbus for the sportnationals this weekend if you are there look me up and I will try to help you some. Johnny Ulinskas ss/ka 3356.
Johnny U is offline   Reply With Quote
Old 09-21-2010, 10:22 AM   #6
Fred Lee
The Buick GS Nationals are normally held in Bowling Green, Kentucky every May. This year the track was flooded and the event was rescheduled for October 20-23. If you can make the trip it is a good place to talk to a lot of Buick engine builders and racers.
The swap meet is pretty good also. I am going to be selling my 455 Buick parts there. Let me know if you need extra heads, block, intake manifolds, Q-jets, etc. My son lives in Norwalk, Ohio and we are going there this weekend. Call my cell phone 231-740-5534 if interested. Fred Lee
Fred Lee is offline   Reply With Quote
Old 09-21-2010, 07:30 PM   #7
Tom Rix
Mike,
I use Automotive Machine and Performance in Philpot, KY (just outside Owensboro, KY) to build my 455 Buick motors for both SS and Top Stock. These guys build Buick engines 365 days a year and usually enter a Buick engine in the PHR Engine Master's.
Ask for Mike or Bobby, 270-729-5556 www.automachperf.com
PM me if you have any specific questions.
Tom
Tom Rix is offline   Reply With Quote
Old 09-21-2010, 08:03 PM   #8
Dean3870
Thank you so much every one, this is so much help you have no idea. I have a long road in front of me this winter, but with this kind of suport i think ill be just fine! Tom, you have a P.M. thank you all so very much, and have a great day
Mike Dean
G/SA3870
Old 09-22-2010, 10:12 AM   #9
Greg Hill
Liked 279 Times in 68 Posts
Mike Dean
G/SA 3870
Mike I think Parsons and Myers are fairly close to you and I can highly recommend them. Hot Rod is as good as anyone doing stock eliminator type machine work and Bruce is very smart with cam combinations and everything else.
Greg Hill 4171 STK
