View Poll Results: What would you do?
Report him 25 26.88%
Give him a chance to do the right thing 58 62.37%
Ignore the situation 10 10.75%
Multiple Choice Poll. Voters: 93. You may not vote on this poll
Old 09-24-2010, 01:44 PM   #1
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Wink Re: What would you do?
Cut his "Nuts" off !
Talk to him ...... and then cut his "lug nuts" off! Jim
Old 09-24-2010, 01:59 PM   #2
race watcher
Default Re: What would you do?
Do you think the infraction of the rules is an advantage? Does this competitor race in your in your class and effect you directly ie heads up? Has this competitor been through tech and tear downs? If the answer is yes to these questions use the same technology and beat them. If you cannot then move on.
race watcher is offline   Reply With Quote
Old 09-24-2010, 02:14 PM   #3
Jim Wahl
Jim Wahl's Avatar
I would submit that it makes no difference whether or not the offender is in your class or not, or effects you directly. If you KNOW the racer is in violation it is your duty to your fellow racers to say something. I would suggest speaking with the offender, if that gets no results, then go to the proper tech official.
By your way of thinking, if the guy uses ported heads then you should use them also! Move on? No. It's called RULES. They are there for a reason. Jim
Old 09-24-2010, 02:22 PM   #4
Chad Rhodes
wow. Too many variables to answer with three options in a poll. If I know a guy is blatantly cheating, such as claiming 396 with a 427 or running a carburetor that is way too big, or nitrous or delay box, etc. then I would go directly to tech and point it out, and possibly protest him if need be. If its something less obvious ( suspected acid heads or wrong pistons, light crank, etc) then I would only protest him if it were someone in my own class, and only if i was sure. Something grey area or unstated, I'd say is probably racers just being creative. I may ask tech if "XXXXXX" is legal, and if not they may want to keep a look out. If its something that has no measurable effect, or is just nit picking then its not worth worrying about.
I'd also venture to say thay if you got on the wrong side of someone in tech, they could probably find something to throw you out for. Usually they are good about small items, saying "change that before you come back". I most definitely would not want a reputation as a "tattle tale" amongst the tech department. I've found that most of the division guys are very helpful, I never hesitate to call them if I have a question.
Chad Rhodes 2113 I/SA
Old 09-24-2010, 02:28 PM   #5
Jim Wahl
Jim Wahl's Avatar
Exclamation Re: What would you do?
Any car can be thrown out any time if a tech guy wants to. Something can be found on any car. We all know that. We depend on our tech guys to be fair and reasonable. Jim
Old 09-24-2010, 02:39 PM   #6
Chad Rhodes
exactly why i will never nitpick some guy's car to tech. Major violations are just that, major. They should be brought to the attention of tech. But minor stuff should be discussed amongst ourselves.
Old 09-24-2010, 02:42 PM   #7
Jim Wahl
Jim Wahl's Avatar
Thumbs up Re: What would you do?
Agreed! Jim
Old 09-24-2010, 02:46 PM   #8
Chad Rhodes
Agreed! Jim
on the flip side of that. the first time I take the I/SA camaro out to a divisional I will make sure Wesley goes over it with a fine toothed comb. If there are any "fix its" or things that need clarification I will get it straight from the horse's mouth and not have to worry about someone else "tattling" on me or saying "such and such on your car isn't right."
Old 09-24-2010, 03:12 PM   #9
Wade Mahaffey
Wade Mahaffey's Avatar
Liked 17 Times in 7 Posts
I would take what I thought to be an infraction, to a tech offical and ask him to explain what was acceptable to me. I would not tell on the competitor, unless it cost me a heads-up match strickly because of the infraction. In other words if his/her car was .20 quicker than mine, and the infraction was worth .05 I think I would let it go. It's sad that the rule book paper and the ink are starting to merge together...it's all turning gray. I had a situation in which I wanted to do something. I called Wesley Roberson and he said absolutely not. As I did my own investigation I observed multiple infractions. I brought that to the NHRA (no names) after a few months of hounding Bruce, he told me to go ahead as I wanted. The wording was changed the following year in the rule book, to provide this infraction as legal now. My point was that I did not want to make waves, but simply wanted to be afforded the same book as everyone else.
Wade Mahaffey
Wade Mahaffey is offline   Reply With Quote
Old 09-26-2010, 05:42 AM   #10
Jason Fuller
Guest
Posts: n/a
Not one stock eliminator crank has been inspected....really?
All I know is my fathers B/SA is so rule compliant and truly stock and we used to be the fastest back in 1993-1994 ....I know cutting down the crank and, offset piston pins along with lightening the crank as well with making our stock intake manifold act like a single plane with micro holes where tech can't see and a lot more stuff has our combo to be....well...very fast...not our stuff but everyone else's...I'm sure if I was in teardown and lead the tech to more of these such gray areas we could all play on the same playing field, otherwise its a joke.....We are the most legal car out there and being stomped on......its not fun....not fun at all.
