Old 09-24-2010, 07:32 PM   #8
Mark Callanan
Liked 64 Times in 14 Posts
Default Re: Q jet Question
Originally Posted by Dave Ribeiro View Post
Mark,
I would try another gauge, if you can't find one , turn the pressure down to 4 lbs and see how that runs & feels ? If it works , it may get you by for this weekend .... If it doesn't work, adjust in 1/2 lb increments till it get better... Could try another carb ? Also , try ; turning on the pump & look down into carb to see if it's bleeding over with too much pressure ? ........... Good Luck .........
David
Good call the gauge was bad
Mark Callanan 1027 STK
Mark Callanan is offline   Reply With Quote
