Old 09-30-2010, 06:13 PM   #2
FED 387
Liked 333 Times in 180 Posts
Exclamation Re: Spool Splines
Strange and M-W use a different degree on their splines---THEY ARE NOT INTERCHANGABLE between each other if that is what you are asking !!!!!!! For instance A 35 spline MW AXLE WILL NOT work in a Strange spool and vice versa--Same for the other spline count-Moser will put either company"s spline in their(Moser) products but you hafta let them know WHEN you order from Moser--Hope this helps---Comp 387
