Old 10-02-2010, 07:44 AM   #11
Default Re: Wiring a stocker?
Robert,
You would need to contact Biondo racing to what options they have.
When it comes to wiring I get pretty anal. By far this is the best panel I have ever used. ARC is a nice setup, but they do not offer the features that the Mega Panel does. The Maga Panel was designed by Biondo Racing, and is well though out.
Steve, very minor difference between K&R and Biondo. The price is one and the style of coarse. I like the round illuminated start button, very nice and very trick. The Biondo Maga Panel also comes in many different configurations.
Old 10-02-2010, 08:33 AM   #12
Mack Reeves
Mack Reeves's Avatar
Liked 44 Times in 13 Posts
Originally Posted by Robert Simpson View Post
Gary, I will call you later about the switches, thanks for the reply. Is this what you put in the stocker? Or the SS only?
Mack, is this what you are putting in your new car? That does look trick.
Ken, that is what I was thinking. Did not know Biondo sold that. Do you know if they will produce a switch panel with more switches that what was shown? I have a switch for my 3 step etc?
Thanks guys keep the ideas coming.
Robert
Robert, Yes I'm putting the K&R in the new car... I also have one in my Barracuda that has been there for 4 or 5 years... Not as much as a blown fuse... I'm sold on K&R...... The K&R also comes complete with marked and color coded wire, wire ends, shrink wrap and wire ties... Just run your supplied power to relay/fuse panel and pull supplied wires from there.... I'll try to get a picture of mine..... Just my .02........ Mack
Mack Reeves
2377 STOCK & SUPER STOCK
Old 10-02-2010, 10:59 AM   #13
Greg Hill
Liked 279 Times in 68 Posts
Originally Posted by Stevie Ficacci View Post
the ARC (116-8000R) and Biondo (DDI-1036-B) switch panels are about $250 and the K+R (572-SD-SPD) panel is $500. whats the difference?
Steve, the K&R is much more than just a switch panel it includes a circuit board with all relays, premium wiring that is marked every 6 inches, all connectors, heat shrink, and one cord that goes from the switch panel to the circuit board. i used this on my son Andrew's car last winter when I built it, and I am going to re-wire my car this winter with the K&R product. Check it out on their web site.You will not be sorry you used this. A lot of the finest car builders in our industry are using this including PK race cars and B&B race cars.
Greg Hill 4171 STK
Old 10-02-2010, 03:10 PM   #14
Mack Reeves
Robert here is the K & R Switch panel... As Greg already said one cable from this to relay/fuse panel...
Sorry for the BIG pictures...
Mack Reeves
Old 10-02-2010, 07:49 PM   #15
Robert Simpson
Liked 20 Times in 12 Posts
Thumbs up Re: Wiring a stocker?
Mack, thank you for the pictures, they are just the right size. Are you mounting your MSD close to that panel? Thanks and I will look into what everyone suggested.
Robert Simpson is offline   Reply With Quote
Old 10-02-2010, 08:03 PM   #16
Kirk Morgan
Liked 81 Times in 45 Posts
There is one small draw back on that K&R panel. There is one 15 amp fuse that controls the power to the switch panel harness and if it pops you have no switch panel functions at all. Emmons was fighting this problem on there Camero at Ennis last weekend. It appears the alt. was causing this problem, but there a couple of other items on that circuit that could be the problem.
Kirk Morgan is offline   Reply With Quote
Old 10-02-2010, 08:36 PM   #17
Mack Reeves
No Robert... I'm using the FAST ingition..... Mounted under the dash.... Mack
Mack Reeves
Old 10-02-2010, 09:51 PM   #18
Robert Simpson
Kirk, I did not know this. What other items on that circuit do you think there is a problem? Are the Emmons considering changing?
Old 10-02-2010, 09:54 PM   #19
Robert Simpson
Talking Re: Wiring a stocker?
Sorry Mack I knew you are finishing a new DP...really I knew it...LOL...Thanks again.
Old 10-02-2010, 10:08 PM   #20
Robert Simpson
Robert,
Here is a link to some nice switch panels that I have used myself. You can't beat it for quality and ease of use and install. They come with everything you need, very trick.
http://www.biondoracing.com/MegaPanel.shtml
Ken, is your "fuse panel" mounted on a same panel as your ing box? If possiable would you send me a picture of how yours is layed out? I will e-mail Biondo next week. I like the ARC but I have a problem with the switches, if one goes out you are in a world of hurt. I mean you can not just replace the one switch. Thanks again.
