Old 10-14-2010, 08:20 PM   #1
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Default Re: Source a Small Journal SBC 350" Crankshaft
Originally Posted by Larry Fulton View Post
I've got a really nice Small Journal 327" block that I want to build into a 350" or bigger... Whats out there and avail?
Thank You in advance!!
Larry
there's NO OEM small journal 350 cranks.
i'd think aftermarket only..
Old 10-14-2010, 10:56 PM   #2
Jeff Lee
Jeff Lee's Avatar
Put a 283 crank in it and have fun!
Jeff Lee 7494 D/S '70 AMX
Old 10-15-2010, 04:42 AM   #3
Tom keedle
Tom keedle's Avatar
uhh, he wanted bigger but i agree with you
Old 10-15-2010, 07:51 AM   #4
Owen S Quirion
Jeff, Great Idea, I did a 302 for a customer of mine last year with a .650 lift roller, some Dart Heads, and a Tuned Port Injection set-up. It runs on E85 and sounds like an Indy Car. It is in a 67 Camaro Street Car with a flat hood and 4-speed. Fun car.
BF/S 1985 Grand Am 3.0 V6
Owen S Quirion is offline   Reply With Quote
Old 10-15-2010, 08:28 AM   #5
Tom Meyer
Liked 354 Times in 120 Posts
If I remember right will the big joural crank swing in a small journal block with out a lot of grinding, some 283 s won,t take a 327 crank.
Tom Meyer 5240 SS Stock ???
Old 10-15-2010, 10:08 AM   #6
Dwight Southerland
Dwight Southerland's Avatar
Liked 784 Times in 196 Posts
I don't know if there is a readily available small journal aftermarket crank with that stroke. It is not difficult to have a 350 crankshaft machined to fit. If you do that, you could then use small journal rods to make the historically infamous "9/16 stroker" and make 368 cubic inches. Tom Meyer is correct, you should check clearance in the crank case before you start assembling.
Old 10-15-2010, 10:38 AM   #7
Larry Fulton
Larry Fulton's Avatar
I believe your quote is incorrect...
The first 295HP / 350" in '67 were o.e.m. assembled Small Journal Cranks...
It wasn't until jan / feb '68 production that GM went to the Large Journal 350"...
Dwight, is my memory correct?
(I'm done with the 283" stuff / just sold the 721 blocks, cranks, etc that I had been sitting on forever)
Thanks again! Larry
Larry Fulton
Larry Fulton is offline   Reply With Quote
Old 10-15-2010, 11:34 AM   #8
Mike Pearson
Mike Pearson's Avatar
Liked 1,988 Times in 600 Posts
Thanks again! Larry
If you could find one it would be extremely rare. I have never seen a small journal 350 crank. You would be much better off using a 4 bolt main block. Unless you have one of the very early 327 blocks they are not reliable. I ran them for several years in my car and had lots of split cylinders. Switched to large journal cranks and 4 bolt blocks no more problems. Better yet get a bowtie block.
Mike Pearson 2485 SS
Old 10-15-2010, 12:25 PM   #9
Larry Fulton
Good advice!
Larry Fulton
Old 10-15-2010, 01:07 PM   #10
Dwight Southerland
The '67 350 was the first designed large journal engine. The block design, etc. was updated to accomodate the bigger stroke and crank. I have never known of a factory small journal crankshaft even being designed.
