Old 10-26-2010, 07:42 PM   #8
Mack Reeves
Mack Reeves's Avatar
Liked 44 Times in 13 Posts
Default Re: DP wiring
Originally Posted by magnumv8 View Post
wire the relay like this.....
pin 30 goes to the pump
pin 87 is your power for the pump
pins 85 & 86 are the relay coil for activating the relay, wire as necessary for compatibility with your ECU.(some are positive switching and some are ground switching)....
lastly, wire your momentary switch (fused) with the connection going to pin 87A of the relay.....
this allows everything to function normally while allowing you to supply power to run the pump with the computer "off"...this also won't cause a "back-feed" condition into the computer which could damage it......
D L Rambo......
Thanks for the info..... Will set mine up this way also.... Mack
Mack Reeves
2377 STOCK & SUPER STOCK
