Old 11-01-2010, 03:57 PM   #11
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: Block Rust Removal
Tree,
I picked up some stuff called Fluid Film at the PRI last year. This stuff is GREAT! It says "for quick and effective corrosion control and lubricant". Get some and fog the blocks with it. No rust or corrosion again! Jim
Old 11-01-2010, 08:19 PM   #12
Rick Bailey
Rick Bailey's Avatar
Liked 10 Times in 7 Posts
Default Re: Block Rust Removal
Malt Vinegar...............click on this link look at ALL the pics..........
http://www.cookhaus.co.uk/vinegar/index.htm
Rick
Rick Bailey 3439 SC
Rick Bailey is offline   Reply With Quote
Old 11-02-2010, 01:22 PM   #13
Jim Wahl
Jim Wahl's Avatar
Rick
WOW! If this is true, I have git to try this! Those parts look as if they are brand new off of the shelf! Hard to believe. Jim
Old 11-02-2010, 02:03 PM   #14
treessavoy
Liked 4 Times in 4 Posts
Wow!
That's some amazing results but I would have to buy it by the 5 gal.cans in order to soak a block.
I think I'll fill my parts washer with the stuff, not only will it clean parts but if we have a fish fry all you have to do is dunk the fish in the parts washer if you want vinegar.......cool!
JimR
Jim Rountree
Old 11-02-2010, 03:06 PM   #15
Dgal
You can use white Vinegar, also. Vinegar is acidic and will fairly gently remove the rust from metal, but be gentler on the other parts. I would rather use it over the more aggressive products on the likely chance it gets on things I don't want hurt.
Don
Dgal is offline   Reply With Quote
Old 11-02-2010, 06:03 PM   #16
Harry 6674
I've had good luck using electrolysis on cylinder heads,should work good on a block. Just need a large plastic garbage can,battery charger(adjustable),soda wash and away you go.
Harry 6674 is offline   Reply With Quote
Old 11-09-2010, 02:13 AM   #17
Greenlight
Liked 79 Times in 22 Posts
Here is something that really works.
Get a plastic 55 gal. drum, add ~20 gal. of water, and 2 gal. of molasses (or any other 10:1 ratio quantity).
Let it sit covered for 3 or 4 days.
Place the engine block (or any other rusted metal) in the solution and let it sit for ~2 days.
It will look like new with all of the rust removed from every nook and crannie. The fermentation process that takes place causes the solution to react with iron oxide (rust) and not with iron. The solution is good for about 3 to 4 months.
The negative side of this process is the odor. After a week or two it can really begin to smell, so keep it covered.
You can buy molasses at a farmers feed store or on the internet.
Greenlight is offline   Reply With Quote
Old 11-10-2010, 04:41 PM   #18
Harry 6674
But what if a bear eats your rare heads or block?
