Old 11-11-2010, 12:28 AM   #1
Chad Rhodes
Default Re: What Do You Think About This?
Originally Posted by Toby Lang View Post
Using the wrong carb is nothing new. People have been kicked out for it many times before. I think most people do it to move up the qualifying sheet then put the legal carb back on for eliminations.
As far as I know the penalty for getting caught with the wrong carb is only a DQ from that race. There is no suspension. Someone correct me if I'm wrong.
Bolting on a bigger carb is probably the easiest way to cheat. I think it should deserve more than a one race suspension.
-Toby
I think bolting on a bigger carb falls under "flagrant" violation and would receive a suspension. being .003 over on the cam isn't flagrant, neither would being .005 over on venturi size, however having the WRONG carb that is bigger isn't a mistake
Chad Rhodes 2113 I/SA
