Old 11-07-2010, 03:16 PM   #41
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Default Re: Stock and the late models, a solution.
My thoughts
Computer controlled cars in their own class.
Carbuerated cars in their own class.
Combine sticks and autos within each class.
Five year limit on engine spec. changes.
Remove non factory size cranks and rods from blueprint spec.
Twenty year old cars or older get Edelbrock heads.
No throttle by wire.
If the factories can fool NHRA on the initial HP. ratings of the engines, it would be no problem to fool NHRA on the capabilities of the computer. With throttle by wire several functions are available in real time : traction control, track position, adjusting E.T. for the perfect run, delay, and a host of other capabilites. No throttle by wire, the temptation is just too inviting!
Best ideas yet ! Especially the head, rod, and crank rules.
Old 11-14-2010, 10:54 PM   #42
skills
Liked 8 Times in 1 Post
For us mechanical challenged people what does throttle by wire mean?
skills is offline   Reply With Quote
Old 11-14-2010, 11:16 PM   #43
FINESPLINE
FINESPLINE's Avatar
Instead of solid linkage or a morse cable from the pedal to the throttle body there is nothing but a position sensing solenoid on the pedal and the TB connected by an electrical wire. -----John
FINESPLINE is offline   Reply With Quote
Old 12-07-2010, 01:25 PM   #44
vic guilmino
Liked 56 Times in 21 Posts
good job ken
this going the right way
some ideals for nhra
Vic Guilmino 1129 STK
