Liked 783 Times in 195 Posts
What bellhousing bolt pattern does the 5.7 Hemi use?
Liked 70 Times in 22 Posts
The new Hemi has the small block engine bolt pattern but the starter is on the pass side. I just got a Quicktime bellhousing but opted for a driver side starter so I might be able to use 340-360 headers with some mods. It fits fine.
Stewart Way 2424 SS |
Banned
Liked 235 Times in 110 Posts
Did you know that a late model Ford racer was DQ'ed for having the starter on the wrong side from OEM? Dont remember if it was stock or S/S but thinking it was a S/S Mustang this year. It might be worth looking into to see if its 100% legal to move the starter if your building a stocker or S/S. I believe this happened in Div.1.
So that means they can use a small block 904 or 727?
Goin over to the dark side Dwight? lol
Ed Wright 4156 SS/JA |
Liked 502 Times in 130 Posts
Be a maverick and hang a crashbox 833 behind it....
Yes all the DP motors are SB even the new 450HP viper motor is too, I know my DP came with a viper 6 speed. Eric
Eric Merryfield 1883 STK |
Dwight
727 or 904. I have been using a gutted 904 for mockup on my SSGT car but I'm going with a Gforce.
Liked 880 Times in 311 Posts
Yep X Tech,
That is the same thing I've been told about my V-6 Super Stocker. Correct side for the starter. In SS/?X classes you can put the starter anywhere. In SS/DS (modified stock) I've been told the starter has to be locaterd in the origional location. I wouldn't be too quick to move it in Stock or SuperStock. Better be careful that could be a way to leave a race early.
Adger Smith (Former SS) Last edited by Adger Smith; 11-17-2010 at 05:25 PM. Reason: sp |
Guess I Better check with NHRA. Maybe on a GT car I can claim I kept the starter on the original side, or not?
Did a little checking in my 2009 Drag Pak book and the cars came with a viper trans for the stick and a 904 case for the auto. Since the starter bolts to the trans with a 904, I think the correct side will be the drivers side. The viper is a little tougher to figure out. The photo I have shows the starter to be on the same side as the clutch fork but either the photo is reversed or the fork is on the passanger side. Anyone with a drag pak care to say whichside the starter is on?
