View Poll Results: Opinions on consolidating classes | |||
Combine Sticks and Automatics |
33 | 14.73% |
Spread Weight Breaks (i.e., .5 for upper classes, .75 for some, then to 1.00 lb breaks) |
22 | 9.82% |
Both of the above |
36 | 16.07% |
LEAVE IT ALONE! |
133 | 59.38% |
Voters: 224. You may not vote on this poll |
Thread Tools | Display Modes |
#31 |
Liked 1,898 Times in 426 Posts
Here's a very quick rough draft:
AA 7.0 to 7.99 10.6 A 8.0 to 8.99 11.0 B 9.0 to 9.99 11.5 C 10.0 to 10.99 11.8 D 11.0 to 11.99 12.2 E 12.0 to 12.99 12.4 F 13.0 to 13.99 12.8 G 14.0 to 14.99 13.1 H 15.0 to 15.99 13.4 I 16.0 to 16.99 13.6 J 17.0 to 17.99 13.9 K 18.0 to 18.99 14.2 L 19.0 to 19.99 14.6 M 20.0 to 21.99 14.9 N 22.0 to 23.99 15.4 O 24.0 to 24.99 15.9 P 25.00 and higher 16.3 Automatic indexes would be 0.05 higher. To merge the FWD cars, you'd use a weight offset to get them to a class where they're at a similar index. For example, the rule might read, " FWD cars run in a class 3.0 pounds heavier than their published factor". Instead of the wide weight breaks currently in FWD, you'd narrow them up. For example, a A/FS FWD car that factors at 13.0 would be given a 3.0 offset, to make it a 16.0 factor. That would make it an I car with a 13.6 index, dropping their index 0.25 (almost all the indexes for the consolidated classes stay the same or get lower). You could either continue to run stick and auto together with a weight break, or separate them. Counting separate classes for stick and automatic, you'd only have 32 classes, as opposed to the current number of around 45-50.
Alan Roehrich 212A G/S Last edited by Alan Roehrich; 11-24-2010 at 06:49 PM. |
#32 |
Liked 26 Times in 11 Posts
Alan,
That is an excellent proposal, nicely done. But while you are at it, can't you slide the letters up and eliminate AA? See you at the races, Wayne Kerr |
#33 |
Liked 32 Times in 19 Posts
Always an interesting discussion. similar results. Many still satisfied as is...No interest in change even if it would be good for S and SS. I would be interested in WHY people care one way or the other. That would be enlightening.
Want no change, WHY? you still take the same car, still race bracket style 90% of races. Still have same cars to race with class plus some more to make it more fun when allowed. Answers? |
#34 | |
Alan Roehrich 212A G/S |
#35 | |
Not that it makes any real difference, other than the fastest class being called "A" instead of "AA", and the slowest being called "Q" instead of "P". There is however a serious problem with that old quick and dirty rough draft. It's brought on by the "new" cars. If you allow the new cars to run at 7.0, they'll likely be fast enough to pose a safety problem on a 9" tire. Yes, I know, there are a lot of "10.5 Outlaw" cars out there running real fast. The difference is, it is rare for them to have a race without a crash of some sort, where it's fairly rare to see cars in Stock crash. Also, the speeds would far exceed the current safety equipment standards for Stock (which are really set for a 9.90 or so ET at 130MPH). You just can't safely run 8.90 at 150 on 9" slicks, with stock seats, relatively stock suspension, and a cage that cannot even extend through the firewall. A 7.0 to 7.99 10.7 B 8.0 to 8.99 11.0 C 9.0 to 9.99 11.5 D 10.0 to 10.99 11.8 E 11.0 to 11.99 12.2 F 12.0 to 12.99 12.4 G 13.0 to 13.99 12.8 H 14.0 to 14.99 13.1 I 15.0 to 15.99 13.4 J 16.0 to 16.99 13.6 K 17.0 to 17.99 13.9 L 18.0 to 18.99 14.2 M 19.0 to 19.99 14.6 N 20.0 to 21.99 14.9 O 22.0 to 23.99 15.4 P 24.0 to 24.99 15.9 Q 25.00 and higher 16.3
Alan Roehrich 212A G/S Last edited by Alan Roehrich; 11-24-2010 at 07:09 PM. |
#36 | |
Banned
Liked 235 Times in 110 Posts
#37 |
That won't happen any more quickly than any adjustments to the AHFS will solve the problems.
#38 | |
Liked 6 Times in 4 Posts
Consolidating classes would be fine for the people who are already on the full pound break. Example...A/SA, C/SA, E/SA, G/SA, etc. What about the people who are in B/SA, D/SA, F/SA, etc? There is a lot more to do than just adding or removing weight to fit a full pound break if you are looking at running heads up against already proven combinations in a class. Maybe that is why there is not an overwelming interest in change even if those who are agenda driven THINK it would be good for S or SS. You want something good for S or SS. Try this agenda...LEAVE THE CLASSES ALONE. PS> Looks like a majority in the poll kinda feel the same way. Hahahahahahahahahahahahahahahahahahahahahahahahaha hahahahaha |
#39 |
Alan, I suggested the same 3 lb. deal to Len (NHRA) when they combined and eliminated the FWD classes years ago. It didn't seem to matter to them that at the time I either was involved with or owned 6 FWD cars. I was just flat ignored!
#40 |
Give the Mustangs & DPs 100 hp
Ed Wright 4156 SS/JA |
