Old 11-25-2010, 06:37 PM   #18
Bill Edgeworth
Default Re: Steel vs Aluminum driveshaft
Originally Posted by FED 387 View Post
Mr Edgeworth some???? If a 4 inch diameter mild steel tube weighs about 4 times more than a 4 in diameter aluminum tube wouldn't there be some advantage in not having to accelerate that much mass either in HP required or ET resulting from the reduced weight??? Take for example that a .065 steel tube weighs about 3 pounds per foot vs a similiar sized alum tube weighing about .7 pounds per foot there just has to be something here and not just reduced vehicle weight dont ya think????
I can understand harmonics to an extent and the need for OEM vehicles to meet CAFE mileage requirements so the vehicles weigh less but the OEM guys used Steel Deriveshafts for millions of vehicles over the years and really never had any vibration problems so I cant believe that the OEMs replaced the Dshafts for that reason had more to do I bet with vehicle weight that any thing else.
Perhaps you can mathmatically calculate the difference in performance between the 2 or is it too small to actually make any difference---Forget about cost of a shft it is inconsequential just raw performance numbers if ya can please---Thanx Comp 387
To answer your question yes. What you describe would be more of an apples to apples comparison. Same size shafts, same final surface speed half the weight half the energy required to accelerate to speed.
Bill Edgeworth 6471 STK
Bill Edgeworth is offline   Reply With Quote
