Old 12-01-2010, 04:43 AM   #1
Brandon Altstadt
Default Front control arm bearings.
I would like to replace my much worn control arm bushings with bearings. Does anyone know who makes a good set for a 1981 Cutlass? I am working on setting this up as a stocker with a 307 olds motor. Thanks in advance.
Brandon Altstadt is offline   Reply With Quote
Old 12-01-2010, 06:43 AM   #2
KingReptile
Default Re: Front control arm bearings.
Dont use polyurethane bushings stay with a stock soft bushings.They should be available anywhere!
KingReptile is offline   Reply With Quote
Old 12-01-2010, 08:13 AM   #3
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
global west . della-lum bushing kits work well. they use an aluminum outer shell with a delrin bushing and, inner sleeve.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 12-01-2010, 10:11 AM   #4
Chad Rhodes
this
Chad Rhodes 2113 I/SA
Old 12-01-2010, 10:40 AM   #5
Billy Nees
I'm with him! Leave the rubber bushings in it. You won't be sorry.
Billy Nees 1188 STK, SS
Old 12-01-2010, 11:16 AM   #6
mannymen
Liked 13 Times in 7 Posts
Wisecarver roller bearings if cost isn't an issue
N/A
mannymen is offline   Reply With Quote
Old 12-02-2010, 03:46 AM   #7
Brandon Altstadt
Wink Re: Front control arm bearings.
Thanks yall. I think I'll get the del-a-lums they seem to be the best option. I have been really looking at the suspension and chasis before putting money into a stocker motor and without help I would be buying more parts that would just sit and collect dust.
Old 12-02-2010, 10:37 AM   #8
Greg Hill
Liked 279 Times in 68 Posts
I've had good luck with the afco steel bushings. They are a lot less money that the del-a-lum ones and work very well. No drag at all.
Greg Hill 4171 STK
Old 12-02-2010, 11:23 PM   #9
Todd Boyer
Liked 6 Times in 5 Posts
Why not use polyurethane bushings ? I always thought they would be smoother dynamically than rubber.
Old 12-03-2010, 11:49 PM   #10
KingReptile
Talking Re: Front control arm bearings.
Because there stiffer you want the front as loose as u can get it st least in my application and many others..
