Old 12-11-2010, 10:45 AM   #1
340Cuda
Liked 805 Times in 341 Posts
Default Re: Need Help with fastener in ClassicTrailer
I have a Classic trailer and its a square headed driver that fits those screws, at least that was all I found in my tool box that worked.
Bill
Old 12-11-2010, 10:53 AM   #2
FED 387
Liked 336 Times in 183 Posts
ya also might have what is known as a clutch head screw they kind look like a figure 8---most likely ya have a #2 square head screw---Mobile homes,RV and trailers use the #2 screws a lot do not strip out the slots in the head as easily as a phillips does especially if ya are installing self drilling fasteners--Comp
Old 12-11-2010, 12:43 PM   #3
Liked 5,156 Times in 1,969 Posts
That makes sense. 8 pt, dual # 2 square driver. Commonly available from Black and Decker.
Just shows how much I know about enclosed trailers ...
Old 12-11-2010, 01:29 PM   #4
Sean Marconette
Sean Marconette's Avatar
Liked 276 Times in 77 Posts
I thought it was a stupid question to ask, but I am glad I did.
As always thanks everyone.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 12-11-2010, 04:20 PM   #5
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
Yes they are square drives. I have a Classic and replaced all the screws on the front stainless trim panels. It took me a while to figure out what fit and how to get them out......I used a drill driver and all you need to do is use a hammer and give the screws a couple taps with the driver in the screw. Then they come right out and I replaced them with stainless screws. Interior screws should be no probelm with rust.......
Rich Biebel
S/C 1479
Stock 147R
Old 12-11-2010, 06:13 PM   #6
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
it's a #2 Robertson head (ah canadian thing)
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 12-12-2010, 12:19 AM   #7
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
Nope, not a Robertson but agree that it's probably a #2 double square (8 point). I bought a bunch of Torx because they look the same but don't work. At least now I know what to look for.
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 12-11-2010, 06:15 PM   #8
dartman
dartman's Avatar
it's a #2 Robertson screw driver head (ah canadian thing)
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
Old 12-11-2010, 10:21 PM   #9
Greg Reimer 7376
Liked 727 Times in 221 Posts
Cool Re: Need Help with fastener in ClassicTrailer
Snap-On lists an eight point driver bit that is like a #2 square drive bit. I bought and built a Tuff-Shed for the back yard to put bikes,lawnmowers, the edger and the pool chemicals in, it not only had #2 square headed fasteners, it came with a couple extra square tool bits that fit a 1/8" nut driver.I just bought two of the Snap On bits, the receipt is at work,I'll try and remember to look up the Snap On part number for the eight point bit and post it Monday. Somebody remind me if I forget.
Old 12-13-2010, 09:59 AM   #10
Greg Reimer 7376
Snap On part number for the tool bit IS-- BTSS2. It's called a Double square #2 bit. I bought a magnetic bit holder for it, as well, 1/4" square drive on one end,1/4" hex on the other, part# TMBS8 A. Hope this helps. Also Torx are numbered-there is no such thing as a metric or an American Torx bit or fastener.
