12-14-2010, 11:05 PM
#8
Re: Best brake system to hold car on the line?
Originally Posted by Mark Markow
art if your still using the master from the power brake set-up , i'm guessing the pedal is rock hard. it has to large a bore for manual brakes. when running manual brakes you need to go to a smaller bore, and modify the pedal ratio.
i would get a brake pressure guage, and see how much you get at the calipers. usually 900 to a 1000 max should do. i'll bet now your in about the 400 range? if you want send me a pm with some info on the calipers ,master cyl.bore size ,and current pedal ratio, and i'll try to get you sorted out.
Thanks Mark. I'll get that info together and send it to you
Art Leong 2095 SS
