Old 12-17-2010, 02:42 PM   #1
Lyn Smith
Liked 994 Times in 200 Posts
Default GM Aluminum Block I D
A friend came across a GM small block all aluminum block with steel sleeves.It has a casting # 0f 366299. Can anyone tell us how old this block is,or what it was used in. it is a 4 inch bore. thanks lyn
Old 12-17-2010, 02:49 PM   #2
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Default Re: GM Aluminum Block I D
1982 366299 350 - - 4 Chevrolet, aluminium
Bob Pagano A/SA
Old 12-17-2010, 03:06 PM   #3
FED 387
Liked 333 Times in 180 Posts
1982 --------- 350 ci. 4 in. bore "early" bowtie aluminum engine block
Old 12-17-2010, 03:10 PM   #4
FED 387
Default Re: GM Aluminum Block I D 366299
Lyn---that block also has splayed Nodular 4 bolt caps and is for a WET sump oil system
Old 12-18-2010, 02:51 AM   #5
rayfin
What was that engine in? Was it installed from the factory? I never heard of an aluminum factory small block.
rayfin is offline   Reply With Quote
Old 12-18-2010, 11:12 AM   #6
FED 387
Exclamation Re: GM Aluminum Block I D
Guys it is a BOWTIE block---I dunno whether GM ever assembly line installed any Bowtie blocks but I'll bet that they were all aftermarket stuff AND NEVER came in a production vehicle!!! No point running out to your local salvage yard hoping to find one cuz they were/are probably OVER the counter blocks----Comp
Old 12-18-2010, 11:43 AM   #7
Dennis P Chapman
Liked 53 Times in 25 Posts
How much are they worth today?
Dennis P Chapman 1904 STK
Dennis P Chapman is online now   Reply With Quote
Old 12-23-2010, 01:50 AM   #8
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
How many have to be built before its alowed in SS? It says here 2 were built. All aluminum 350 250hp. And I remember reading somewhere that this engine has 11:1 compression too! Probably a bowtie block...and im assuming of the 50 somthing built only 2 or more got this engine.
http://www.indypacecars.com/1982.html
FED 387...you always reply like you are upset. Lighten up its Christmas bro.
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 12-23-2010, 10:11 AM   #9
FED 387
Sorry I upset ya Crate but a bowtie part usually means it was an aftermarket part not an assembly line installed part so no need to start scouring the junkyards for that part. Ya probably aren't gonna find one UNLESS some guy installed the part and then the car was junked. By the way Merry Xmas to you and your family I'm gonna have a great one cuz I just got my 2 year update on my Prostate Operation I'M CANCER FREE----A side note to everbody go get yours checked out it "could happen to you!!!!" The Doc found mine during a routine physical to renew my NHRA license--FED387
Old 12-23-2010, 10:30 AM   #10
CrateCamaro
Thats awesome news brother! I will definitly raise a glass to you next time I have a drink! Merry Christmas!
1700 IHRA H/CM
1701 NHRA SS/?A
