The "red spray stuff" you refer to is Hi Tack and was the sealer of choice for most of us that used steel shims many years ago. Some guys had their own secret sauce (Hylomar, GM brown glup, Super 300 and other conk) but Hi Tack works pretty good.
Dont breathe the stuff cuz it will make you more goofy than Art Leong. TT |
Liked 4 Times in 3 Posts
I've used those black coated GM head gaskets several times and do not use a sealer I think that coating serves as a sealer!
Liked 557 Times in 217 Posts
Copper Coat spray always worked well for me......I've used those gaskets and they work fine but over a period of time and miles they can fail. I have seen them develop water leaks into an end cylinder right next to the dowel pin.....
Liked 205 Times in 93 Posts
here's what i've found....GM # 3830711 steel shim gaskets ordered/recieved have come with a light gray gummy coating on them. .027" thick. there's no "DG" stamp on them like the old days. ("DG" stands for detroit gasket, who was bought out recently by ROL gaskets) the small tab overhanging w/the small ID hole is still present though. im not going to spay tack, the factory coating will be sufficient i'm sure. i will pay close attention to tourque settings/pattern during installation w/ribbs up...thankyou all for you input.
Liked 511 Times in 122 Posts
you may wanna get a composition gasket... the steel shims will rust out in a street car especially one which doesnt run daily...
just a thought ! jack
Jack McCarthy 3609 STK "the Captain" |
Liked 783 Times in 195 Posts
we're going to run an antifreeze mixture in the engine so that should help prevent corrosion?
