Old 12-25-2010, 12:57 AM   #1
FED 387
Liked 336 Times in 183 Posts
Default Re: 12 Bolt GM ?
larry the code ya gave me is what was in that rear originally when installed in the car
BT---3:55 posi
01---January
22---22nd day of the month
G----Detroit Gear & Axle
2----Night shift
E----Eaton Positraction Differential
Housing dimensions are
Center to center of the spring perches----42 3/4 inches
Inside of backing plate to inside of backing plate---53 1/4 inches
Outside of brake drum to outside of brake drum---60 1/4 inches
Old 12-25-2010, 01:28 AM   #2
FED 387
Larry--I forgot to mention that that code is for a 68 or 69 rear end however see what the date code cast into the ribs on the left side of cast iron differential are ---also what is the serial number of your car you might have a very early 70 model and they had left over 69 housings to use up when they built your car
