if the thrust is worn on the back side another words look like crank is moving forward. its most likely the converter is putting pressure on the crank ,or something in the tranny is at fault. also check timing chain alignment.
Banned
Converter Balloning or Input saft to long on a 4 speed
What I have seen that has caused excessive thrust clearance is misaligned pulleys on the front of the engine....this creates pressure forward or rearward on the crank causing either the bearing or crank flange to wear....it takes very little misalignment to create this internal drag especially with a V-belt set up.....
D L Rambo..... |
check the back of the crank where the pilot bearing would be. have found that to be the problem even with convertor spinning free. do not have any measurements.
Ron Waters s/st 1346 |
Liked 13 Times in 9 Posts
Converter ballooning, had it happen even on a low 12-sec bracket car. Had too much line pressure in the valve body at the time, too... no idea if that had any part in it.
If any part needs surface lapping. It should be done in a figure "8" pattern on a surface plate(glass or a highly finished checkerboard steel lapping plate). This is how I was taught when we used to rebuild fuel injection components.
Peter Last edited by Peter Ash; 01-08-2011 at 10:24 PM. |
Liked 165 Times in 59 Posts
do you use a two step ????,also cold runs with thick oil will wipe out the thrust ,,there is a procedure you can do to help this gmonde
Liked 12 Times in 5 Posts
#9 | |
The converter is due for a freshening up and we were planning on sending it out anyways. Thanks for the response. Mike |
