Old 01-16-2011, 09:50 PM   #1
Kirk Morgan
Liked 81 Times in 45 Posts
Default 3310 Holley Carbs
A friend of mine has a bunch of Holley carbs and parts. I can run a 780 on my stocker. Is there any list numbers or metering plate numbers that are better or more desired. He has a GM replacement carb also that is a 780. Any recommendation or suggestions are welcome.
Kirk
Kirk Morgan is offline   Reply With Quote
Old 01-17-2011, 09:51 AM   #2
randy wilson
Liked 22 Times in 22 Posts
Default Re: 3310 Holley Carbs
A 3310 is a 750.
don,t have one
Old 01-17-2011, 09:54 AM   #3
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Originally Posted by randy wilson View Post
A 3310 is a 750.
early ones were designated 780
Old 01-17-2011, 10:29 AM   #4
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Engine tech spec gives throttle bore measurements, use that to check the carb. If it matches you can use the carb.
Bob Pagano A/SA
Bob Pagano is online now   Reply With Quote
Old 01-17-2011, 10:40 AM   #5
Either buy a Quick Fuel, or call Clark Holroyd, or Jimmy Bridges, tell them what you have, and send them what they tell you they want. You'll be time and money ahead.
Old 01-17-2011, 10:58 AM   #6
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
On my flow bench an old 3310 flowed 788 CFM, an old 4780 flowed 780. I still have a few old 3310s, I bought about 8 of them from a friend back in the early 70s, Paul.
Old 01-17-2011, 02:13 PM   #7
Jody Lang
Liked 92 Times in 29 Posts
I thought the 3310 with a "metering plate" was a 750 and a 3310 with a "metering block" with replaceable jets was a 780.
Anyone?
Jody Lang is offline   Reply With Quote
Old 01-17-2011, 07:13 PM   #8
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Difference is in the boosters. 780s have drop down boosters, 750s have straight boosters.
Old 01-17-2011, 09:45 PM   #9
Rory McNeil
Liked 1,111 Times in 304 Posts
Also, the 3310 & 3310-1 have the replaceable secondary jet blocks and are rated at 780, the later (& cheaper versions) 3310-2,3,4 etc use the secondary metering plate and 750 rating. I believe that the later 750 versions also use the Holley manual choke setup, while the 3310 &-1`s that I have owned, always had an automatic choke. Also some of the later carbs used cheap plastic accelerator pump arms, secondary diagpram housings, and manual choke units.
NHRA 6390 STK
M/S 85 Mustang
Old 01-17-2011, 10:09 PM   #10
Jeff Lee
Jeff Lee's Avatar
And if your spec allows a 3310 then you can replace the rear boosters to the drop down for a +30 CFM gain and you can also replace the metering plate with a metering block for easier tuning.
Jeff Lee 7494 D/S '70 AMX
