Old 01-22-2011, 10:41 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default Dana 60 Posi/locker options
Racers,
What are the option for a Posi/Locker unit in a Dana 60? What is the durability of such units?
Thanks
Larry Woodfin 471W
Old 01-23-2011, 05:22 AM   #2
GTX JOHN
Liked 2,486 Times in 697 Posts
Default Re: Dana 60 Posi/locker options
Never had a problem with the posi and we ran it a lot in 70-80s. Boy o boy is it heavy though and the spool is lighter and simpler for a dedicated drag car. Seems like they had 23 spline until 70 and then 35 as i seem to remember.
GTX JOHN is online now   Reply With Quote
Old 01-23-2011, 12:34 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
23 spline to early '69 then 35 spline .
Both 11/2" dia. ...For a street/ race car I'd use the factory posi.
The 6 gear posi is a brute weight wise,but very strong , I'v rarely seen a broken pinion or spyder gear.
I used to add a second bevel spring plate to the pack to increase the clutch pressure. ...A little choppy around turns if you were going slow.
