View Poll Results: .031" Dykes or .043" Rings ?
.031" Dykes 41 33.88%
.043" .155" radial moly ring with lateral gas ports 39 32.23%
.043" .134" radial moly ring with lateral gas ports 31 25.62%
Other, Make suggestion 10 8.26%
Voters: 121. You may not vote on this poll
Old 01-24-2011, 01:40 AM   #1
trmnatr
Default Re: .031" Dykes or .043" Rings ?
Originally Posted by Rich Biebel View Post
I just disassembled a 400 small block bracket engine. Dome pistons.....13+ to 1 compression. .043" narrow radial width top rings with vertical gas ports. The engine has 450 runs on it and still ran fine and rings were not worn out. It is 3 seasons old. I did not build it but I am just going thru it... The car can run in the 9's at 3100+lbs so it is making good power. Never really felt a narrow top ring with gas ports would go that many runs........Well it did and could have run probably quite a few more. The owner uses a restrictor plate to run 10.0's at 7000rpm or so......
Ones that shown wear for us were AP rings which is steel with a C33 coating
I just prefer 1/16" for bracket and .031" Pressure Back for high rpm low drag. I want to try an .031" with a .043" Napier as I use 1/16" x .145" Napier usually
trmnatr is offline   Reply With Quote
Old 01-24-2011, 09:35 AM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
After further inspection of the pistons in the green Camaro.....
ALL the gas ports were plugged with carbon.
The engine is running with low tension oil rings/no evac system and I feel it oiled up top and added to the carbon buildup.
As I said earlier I would not choose this combination myself for a bracket engine that went this long between being rebuilt or this many runs. I would use the std 1/16" top rings. I did use the Hellfires in one engine and they wore the tops of the cylinders. A 555 with Big Dukes....
I ran .031" Dykes a lot in flat piston small block engines. Typical SS type 350's. That was pretty std. 20 years ago.....I ran those rings very high on the pistons. I think they were .050" down on at least one engine. Never had any problem but I was never able to run with the fast guys back then with my budget.....
Rich Biebel
S/C 1479
Stock 147R
Old 02-04-2011, 08:45 AM   #3
trmnatr
You own the green Camaro ED posts the pics of??? If so nice car
We use domed pistons many times, so we cant run the Dykes ring that high but what we do is run it .100 to .200 down depending on dome and valve pockets and turn the upper ring land down so gas pressure can apply the ring
IMO 1/16" is the best damn bracket ring out, 1/16" top, 1/16" Napier Second or Reverse Twist, 3/16" 16 pound oil ring
If I want any more gain from the rings, Dykes, .031"
I do want to try an 1/16" GoldFinish top ring, due to it solving the wear issues with the 043
The GoldFinish is a face coated TNT/Hellfire ring thats lapped too, The GoldFinish 043 is much better than normal 043 rings or AP 043 rings
Old 02-04-2011, 10:30 AM   #4
Rich Biebel
[QUOTE=trmnatr;238064]You own the green Camaro ED posts the pics of??? If so nice car
No it's not mine. Owner is a well known footbrake bracket racer and he also has 2 LT-1 Stockers now.
I agree about the 1/16" top rings...
I am trying a set of gapless 1/16" tops with napier seconds and Hastings style oil rings in my own engine......509 BB ....
This will be an injected alcohol burner this year....I've had good luck with those sytems and am back to one again now.....
Rich Biebel
S/C 1479
Stock 147R
Old 02-04-2011, 02:04 PM   #5
Ed Wright
Ed Wright's Avatar
You guys are talking bracket engines now. Apples vs oranges.
Edit: Wonder why this old one came back up?
Ed Wright 4156 SS/JA
Old 11-22-2014, 12:07 AM   #6
Adger Smith
Liked 880 Times in 311 Posts
Is it because Ed is lost and trying to find his way home?
Adger Smith (Former SS)
Old 11-22-2014, 09:21 AM   #7
Ed Wright
Ed Wright's Avatar
Ed gets lost a lot. He is old.
