Old 01-28-2011, 07:15 PM   #1
smracer2002
Default Re: 94-95 Mustang stocker
My name is Chris,Ken and everyone else.
I have a rear sway bar a guy in Carolina built.
I also have one on my Granada wagon bracket car.
Believe it or not it is 1.625 diameter.It was built to see
if it would work instead of a body mounted bar.
It bolts in the original stock mounting location and works better
than I figured it would.
Eibach and UPR both offer a drag spring set that lots on NMRA
guys use and they seem to work well.The UPRs are built by Eibach
according to UPR.
Already have 15x4s and 15x10s with a 6.5 bs with 10x26s on it.
I know it will be a 9x28 or 9x30 when its time.
Does anyone here use the airbag in the right rear spring?
First On
Race
Day
smracer2002 is offline   Reply With Quote
Old 01-28-2011, 07:43 PM   #2
larry dowty
Liked 11 Times in 4 Posts
chris i have a 95 stocker also and i use a air bag in the right rear.
larry dowty 6388 SS
larry dowty is offline   Reply With Quote
Old 01-28-2011, 11:29 PM   #3
RPM5595
RPM5595's Avatar
Liked 32 Times in 14 Posts
When I ran my car in Stock I used an airbag and crusher springs out of a 1976 Cougar. Keep in mind though I had a LOT of weight in the back to make 3300lbs. in N/SA.
Jeff, the problem with not cutting the springs is the front end of the car sits nosed up, a lot. I cut mine to get the ride height I wanted and never had any troubles. It had great 60' times (low 1.50's) and did big wheelies for a "N" car. C4 with a 2.92 low. 4.86 gear with Hoosier "short" radials.
Jay Roeder
facebook.com/racefuelsales
Former N/SA , Soon to be SS/AS, Renegade Race Fuel dealer
RPM5595 is offline   Reply With Quote
Old 01-28-2011, 11:56 PM   #4
Jeff Lee
Jeff Lee's Avatar
I understand on the springs but if you want it right, you have to find a smaller wire diameter or maybe have some custom made (which is what I did; try finding AMC parts!). It is worth it.
Jeff Lee 7494 D/S '70 AMX
Old 01-29-2011, 02:45 AM   #5
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
The only thing "trick" about Morso trick springs is getting them in the car. If you have to cut them then the spring isn't what it was designed to be. 1 coil won't change the rate much but as Jeff said you're better off with the right spring the first time. If Moroso makes a spring that bolts in and ride height is correct then you're fine. If not, it's a bunch of work to end up with a compromise.
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 01-29-2011, 02:25 PM   #6
mopar jeff
mopar jeff's Avatar
Exactly why I didn't want to mess with it. I figured the rate would go up significantly, and the trial and error cutting can be a pain. Although I have done other things on the car many times, springs weren't my idea of fun. To each his own though.
Low 1.50 60' times is pretty impressive, even in N. I just touched the 1.50s last time out at a P weight. I thought that was pretty good. Oh well, time to keep tweaking the combo.
Jeff Interlicchia
7077 D/SA 1998 Pontiac Firebird LT1
J707 E/T 1966 Dodge Coronet 500
mopar jeff is offline   Reply With Quote
Old 01-31-2011, 12:30 AM   #7
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Thumbs up Re: 94-95 Mustang stocker
Jeff 1.50 in P/SA is pretty good... I run in the low 1.60's I went 1.58 @ O/SA weight.
Old 01-31-2011, 12:40 AM   #8
Jeff Lee
Jeff Lee's Avatar
I've put at least 5 sets of front springs on my car. One custom set was incorrectly made. Instead of using the front half weight, they (mistakenly) used the total weight of the car as the front weight. So I guess I had springs rated at 3200#'s on the front! Or at least I tried. You shoulod have seen me TRYING to compress those springs! When it couldn't be done, I finally said "something is wrong here"! And Moroso doesn't offer a spring and factory springs didn't do what I wanted. Therefore I went custom. And that took a few tries. I used Coil Spring Specialties in Kansas City (MO or KS?). They cost $150 a pair at the time (this was probably 1997 or so) and the springs have NEVER dropped at all. Moroso springs seem to be good for a couple years at best on some cars.
And removing a coil CAN be significant in terms of percentage of spring rate. You'll have to do the math.
