Old 01-28-2011, 11:56 PM   #1
Jeff Lee
Jeff Lee's Avatar
Default Re: 94-95 Mustang stocker
Originally Posted by RPM5595 View Post
When I ran my car in Stock I used an airbag and crusher springs out of a 1976 Cougar. Keep in mind though I had a LOT of weight in the back to make 3300lbs. in N/SA.
Jeff, the problem with not cutting the springs is the front end of the car sits nosed up, a lot. I cut mine to get the ride height I wanted and never had any troubles. It had great 60' times (low 1.50's) and did big wheelies for a "N" car. C4 with a 2.92 low. 4.86 gear with Hoosier "short" radials.
I understand on the springs but if you want it right, you have to find a smaller wire diameter or maybe have some custom made (which is what I did; try finding AMC parts!). It is worth it.
Jeff Lee 7494 D/S '70 AMX
Old 01-29-2011, 02:45 AM   #2
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
The only thing "trick" about Morso trick springs is getting them in the car. If you have to cut them then the spring isn't what it was designed to be. 1 coil won't change the rate much but as Jeff said you're better off with the right spring the first time. If Moroso makes a spring that bolts in and ride height is correct then you're fine. If not, it's a bunch of work to end up with a compromise.
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 01-29-2011, 02:25 PM   #3
mopar jeff
mopar jeff's Avatar
Exactly why I didn't want to mess with it. I figured the rate would go up significantly, and the trial and error cutting can be a pain. Although I have done other things on the car many times, springs weren't my idea of fun. To each his own though.
Low 1.50 60' times is pretty impressive, even in N. I just touched the 1.50s last time out at a P weight. I thought that was pretty good. Oh well, time to keep tweaking the combo.
Jeff Interlicchia
7077 D/SA 1998 Pontiac Firebird LT1
J707 E/T 1966 Dodge Coronet 500
mopar jeff is offline   Reply With Quote
Old 01-31-2011, 12:30 AM   #4
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Thumbs up Re: 94-95 Mustang stocker
Jeff 1.50 in P/SA is pretty good... I run in the low 1.60's I went 1.58 @ O/SA weight.
Old 01-31-2011, 03:23 PM   #5
mopar jeff
mopar jeff's Avatar
Yeah I wonder what kind of ET we could shave by knocking .05 or more off the 60' time.
Jeff Interlicchia
Old 01-31-2011, 07:49 PM   #6
Chris1529
Liked 70 Times in 29 Posts
a tenth
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 02-01-2011, 05:58 PM   #7
mopar jeff
mopar jeff's Avatar
I would love to have that.
Jeff Interlicchia
Old 01-31-2011, 12:40 AM   #8
Jeff Lee
Jeff Lee's Avatar
I've put at least 5 sets of front springs on my car. One custom set was incorrectly made. Instead of using the front half weight, they (mistakenly) used the total weight of the car as the front weight. So I guess I had springs rated at 3200#'s on the front! Or at least I tried. You shoulod have seen me TRYING to compress those springs! When it couldn't be done, I finally said "something is wrong here"! And Moroso doesn't offer a spring and factory springs didn't do what I wanted. Therefore I went custom. And that took a few tries. I used Coil Spring Specialties in Kansas City (MO or KS?). They cost $150 a pair at the time (this was probably 1997 or so) and the springs have NEVER dropped at all. Moroso springs seem to be good for a couple years at best on some cars.
And removing a coil CAN be significant in terms of percentage of spring rate. You'll have to do the math.
Old 01-31-2011, 07:22 AM   #9
Chris1529
I have Eibach's in my car all the way around. no issue with fit or ride height.
Chris Bowman
1984 Mustang GT350
