Old 02-02-2011, 09:29 AM   #6
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default Re: stamped steel rocker arm delection
Originally Posted by Grant Eldridge View Post
The deflection I've measured is about .015" from checking spring to race springs on my 396 stocker motor. This is a combination of the pushrod flex, rocker stud flex and the rocker arm itself, not sure how you'd isolate the amount in the rocker alone but it is significant. NHRA checks lift at the retainer, using a solid lifter of the same height, so you can adjust the lobe lift to compensate for the loss from what I understand....
grant:how much spring presure are you running??i know big blocks have a 3/8 push rod but you probably run a 7/16" or 1/2" and the ratio is 1.7 ,,.015 is not bad i am getting more ..020 -.025 and thats with a 3/8 push rod gmonde
