Old 02-03-2011, 11:00 PM   #1
Chris Hill
Liked 244 Times in 26 Posts
Default 3 speed auto transmissions
Do any three speed automatic transmissions only use one planetary set to get the three forward gears plus reverse? I know it's possible, just don't know if it was ever in production.
Also, is there a good website that shows exploded views of various automatic transmissions?
Thank you,
Chris
Chris Hill
Old 02-04-2011, 08:59 AM   #2
reera
Liked 31 Times in 6 Posts
Default Re: 3 speed auto transmissions
www.wittrans.com has some pretty good exploded views for a lot of different trans makes.
Ryan Walther
Stock 315
reera is offline   Reply With Quote
Old 02-04-2011, 01:05 PM   #3
Chris Hill
Thank you.
Chris Hill
Old 02-04-2011, 01:22 PM   #4
Liked 1,836 Times in 417 Posts
Chris, I don't recall ever working on a 3 speed automatic with only one planetary set. And I worked on most every domestic 3 speed built since around 1955.
Old 02-04-2011, 03:05 PM   #5
Chris Hill
If nobody has produced a three speed automatic with one planetary set yet, there must be a fundamental reason why. It is possible though.
Just haven't figured out yet what it is...
Chris Hill
Old 02-04-2011, 04:18 PM   #6
Jim Cimarolli
Liked 166 Times in 46 Posts
Question Re: 3 speed auto transmissions
Possible how?
Jim Cimarolli is offline   Reply With Quote
Old 02-04-2011, 05:01 PM   #7
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
I've been thinking about this all day and then it hit me , Renault had what was called a ravignaux planetary assembaly that had compound planet gears ..used on a type 4139 trans
I'm looking for one of my old AMC school books,[ they were way better than the Frenchie's manuals ] for a blow up of it. if I remember correctly it had 2 sun gears , 1 annulus gear and compound planet gears.
I'll have to dig thru the stuff I had hoped I'd never have to use again!
Found a description and an excellent engineering web site.
http://www.mathworks.com/help/toolbo...avigneaux.html
Old 02-04-2011, 09:22 PM   #8
Chris Hill
Originally Posted by Jim Cimarolli View Post
Possible how?
You have to connect two pieces together, say the sun gear and the ring gear. If they are connected by a clutch and the input is the sun, the ring gear would have to spin at the same speed.
This is an odd way of doing this, but I think it would work.
Chris Hill
Old 02-04-2011, 10:43 PM   #9
Chris Hill
The issue is gear ratio spread with a single, simple planetary set.
Using VERY ROUGH calculations with a 70 tooth sun and 100 tooth ring gives the following:
Low gear= 2.43:1
Second gear = 1.0:1
High Gear = 0.59:1
These are pretty unrealistic gear ratios for a small block chevy as a three speed. But it was a good thought experiment.
Chris Hill
Old 02-05-2011, 12:24 PM   #10
Greg Reimer 7376
Liked 705 Times in 219 Posts
Cool Re: 3 speed auto transmissions
Looking at the obvious mechanical disadvantage of a planetary overdrive of that configuration, I feel strength would be a major issue. What's on paper doesn't always hold up on the track.
