Old 02-21-2011, 02:49 PM   #9
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
Default Re: Brake problems?
any time you bleed a used master cylinder you have to be careful to not bottom it out.
Are you moving to much volume of fluid? Don't manual brakes use a smaller diameter bore piston. One possibility.
Honda an some other companies screw their hat rotorrs to the hub. One screw w a tapered head, supposedly helps with the pedal. saw it saturday at work. they screwed it together and corrected a shimy and a pedal issue. These are lightweight rotors with heavy clamping on the calipers from your ratio and line pressure. second possibility
Any time I've taken brakes apart you always have to re seat them too.
chris ok is offline   Reply With Quote
