Liked 3 Times in 2 Posts
Not that difficult to do. We have done this a few times when building Stock or Super Stock cars.
First, you don't need to cut off the whole roof. Just replace the side pieces that are cut out for the T roofs. You should be able to easily find the sections from a wreck. Trim them, drill out the spot welds and fit and weld them in place. The inside trim and door/window rubbers are different too, so you'll need them. You'll also need the one piece fiberglass roof panel. A glass guy can remove the old one as well as one from a wreck if you find one. .....and there are no leaded seams!! Hope this helps. FJ Smith |
Hope this helps. FJ Smith[/QUOTE] I figured that ,FJ. I was speaking in generalities . I'd seen a bad example recently.
Didn't body-in-whites come with the roof panels, so they could go either way?
Ed Wright 4156 SS/JA |
Liked 20 Times in 3 Posts
FJ is right, not hard to do. On a previous car, we cut the other top off with piano wire and the fillers (drilled out spot welds) welded in with a little grinding and you are ready to urethane the new top on.
Liked 101 Times in 27 Posts
Anyone east of the Mississippi with experience at this conversion want the job ???? Do you guys want to recommend anyone ????
Rusty,
Give Steve McCreary a call and see if this is something he would tackle. |
