Old 02-28-2011, 12:42 PM   #1
Chris Williams
Chris Williams's Avatar
Default Re: Installing a Throttle Stop
They also have two different styles of connector for their inline stops. I know this because I chose the wrong one, and within an hour of my placing the order on-line, someone called me to say "are you sure"? And of course I was wrong. What amazing customer service.
Give 'em a call, you'll certainly get the help you need.
Chris Williams 6304 SC, TD, ET
Chris Williams is offline   Reply With Quote
Old 02-28-2011, 03:49 PM   #2
SCOTT SST2871
YOU WONT BE ABLE TO MAKE AN INLINE STOP WORK WITH YOUR STOCK CABLE.WHAT I DID ON MY CAR WAS BUY A FIREWALL MOUNT CIRCLE TRACK PEDAL IT WAS INEXPENSIVE (40or SO DOLLARS) IT HAS A TOE RETURN HOOK MADE ON TO IT ALREADY WHICH IS MANDATORY BY RULES AND MADE A THROTTLE ROD OUT OF 1/4" ROD WHICH WILL THREAD INTO YOUR INLINE STOP.JUST BE SURE TO TO MAKE A POSITIVE PEDAL STOP OUT OF A BOLT THATS ADJUSTABLE
SCOTT FIFIELD
SCOTT SST2871 is offline   Reply With Quote
Old 02-28-2011, 04:45 PM   #3
Ken MacNicol
Ken MacNicol's Avatar
Liked 26 Times in 12 Posts
It will work just fine. Mine has been on the car 15 years.
Buy a CSR throtllle stop cable bracket to mount the exterior cable and the interior cable just fits inside the back of the stop with a lock nut.
Ken MacNicol is offline   Reply With Quote
Old 02-28-2011, 09:19 PM   #4
cal
cal's Avatar
Liked 31 Times in 18 Posts
Send a message via AIM to cal
Default Thanks Guys
Thanks guys.
I'll look into the CSR cable bracket, and possible a under carb plate.
Only got 5 weeks or so till MIRs Pro Am race.
I'd like to be ready for it.
Calvin
177X H/R
cal is offline   Reply With Quote
