Old 03-13-2011, 12:36 PM   #1
Maverick
Liked 36 Times in 26 Posts
Default Shift Lghts
I am looking for a shift light system that maybe some of the stick guys are using, or maybe the automatic guys too. I need to have different shift points for each gear, and the transmission I use is a five speed. I just purchased a 5313 autometer, but I am still looking. Any Help would be greatly appreciated. Steve Willie WIlliams
Old 03-13-2011, 02:22 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Default Re: Shift Lghts
Look at the Autometer 5350 digital programmable shift light .
I've been using one for several years, easy to program and use....And its very compact.
Who needs a huge 5" tach blocking their view anymore?
This model has a digital playback and a launch rpm feature which I like for foot brake racing.
Old 03-13-2011, 02:37 PM   #3
Daytona Sensors LLC. They've got a really cool programmable shift light system that is also a basic data logger, and it can be combined with their A/F R interace to give you programmable shift lights (has a staging RPM as well, so if you run a "no box" race, you can stage at the same RPM without a two step) with a multichannel data logger and air/fuel ratio meter.
Old 03-14-2011, 12:32 AM   #4
james schaechter
Thumbs up Re: Shift Lghts
We have a MSD Digital 7 programmable ignition. It has a provision to plug in a MSD shift light that you can do this with very easily. The digital 2 step is much smoother than the analog one too. ( We run a stick also)
James Schaechter 3163 STK
Old 03-16-2011, 10:19 AM   #5
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Question Re: Shift Lghts
Hi
I had one of those and it worked good & I loved it in one car
but when I switched it over to another car with the same Ign. system I had trouble with it blinking and flashing when it was not set to.
MSD said it was R/F interference??
I just took it out.
Did you need any thing special to make it work?
I'd like to put it back in my car.
Thanks
Glen
MEXJOE is offline   Reply With Quote
Old 03-16-2011, 02:21 PM   #6
Tom Goldman
I have one in the Stocker with a Mallory Hyfire V ,and also in the SG car with a MSD 7AL3.
Neither on has ever given me any trouble.
Possibly your tach feed wire is too close to the coil output wires.
Old 03-17-2011, 09:32 AM   #7
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 313 Times in 106 Posts
I usaully keep my hand on shifter so I'm not hunting around in the dark for it.LOL
I can't give any shift light advice never have used one.
Mike Taylor 3601
