Liked 1,919 Times in 432 Posts
Nope. Aftermarket crankshafts are not legal in Stock. I know Olds cranks are getting hard to find. At least good ones are. So are blocks.
Alan Roehrich 212A G/S |
Liked 66 Times in 37 Posts
Do you really need .013 on a 455 Olds??? HAHA If it were SS you could offset grind a 425 crank and use 454 bearings.
72 cutlass |
I don't see any real advantage to offsetting by .013, but that's the way the motor was when I bought the car. If the crank needs to be turned .010 or .020 under, might as well get the minuscule stroke advantage, too. (Note: in the Olds, most stock blocks have the pistons about .030 down in the hole, the offset will reduce the amount you have to deck the block)
Marvin Robinson 3188 STK/SS |
Liked 536 Times in 110 Posts
Marvin: When the crank is stroked .013", it is also "indexed" as well, insuring that the rod throws are truly 90° apart. It shouldn't be too hard finding a suitable replacement crank, I'm not hoarding all of them.
Jim Kaekel 3836 STK |
Good point, thanx for the info, Jim. I think I've got a line on a couple spares (I want to build a spare short block, too. Shure would be nice to just be able to buy an Eagle cast crank.
