Not exactly the type of day to make a record run. He should try Atco in the spring or the Dutch in the fall. That motor was sucking some air !
The QF 780 has metering block on the rear, the 3310 has a plate. The QF has 4 corner a/f screws, the 3310 has primary only. The QF has adjustable vacuum to the secondary diaphragm to control opening rate, the 3310 requires a spring change. The QF has replaceable air bleeds were the 3310 bleeds are fixed. The QF has throttle blade angle adjustment on the secondaries that is external and easy to get to. The QF is much lighter & made of aluminum, the 3310 is cast zinc (?).
I still like the classic gold of the 3310 best. That's basically it. Oh, retail for the 3310 is about $275 and the QF is about $525
Jeff Lee 7494 D/S '70 AMX |
Liked 279 Times in 68 Posts
Jeff the original 3310 has a metering block in the back and was rated at 780 cfm.
Greg Hill 4171 STK |
Liked 880 Times in 311 Posts
I have an e-mail from Mike Baker that says the Quick Fuel carbs are approved in IHRA. I was asking for one of my Crate Mtr. customers.
The blocks in the back of 3310's came on the 3310-1 and -2's Rated 780. They then went to some plastic parts and changed the down leg boosters to straight leg and re rated the later 3310's to 750. Those had the plates in the rear. My memory on the change might be a little fuzzy. It might have changed with the 3310-3 to 3310-4. I'm almost positive all the 3310-1's and 2's have rear metering blocks. I guess I could dig out my old Holley books and check it.
Adger Smith (Former SS) Last edited by Adger Smith; 03-26-2011 at 09:20 AM. Reason: sp |
Liked 6 Times in 2 Posts
Adger, Your right on the secondary metering blocks ! 3310-1-&-2 !..........John
John Lang 365 STK, SS |
Liked 13 Times in 7 Posts
I never knew a 3310-2 was a 780 c.f.m with a secondary rear metering block. I thought any thing after 3310-1 was a 750 c.f.m with a plate. I will keep a eye on the -2 next time at a swap meet.
Liked 783 Times in 195 Posts
Adger - You are basically right. The change to the plate and straight boosters was part of the production definition of the -3 and later carbs. I have seen a -2 carb with straight boosters and a block though.
Then there is the original "3878261-EH LIST-3310" carb that was the start of it all . . . . |
Liked 26 Times in 13 Posts
I thought that carb was legal only in SS. Is it a legal replacement for a 780 in stock?
Bill Harris ex 2172 STK ex 2272 S/S |
Liked 81 Times in 45 Posts
Were you running the carb with or without a power valve.
Kirk,
The new David Cook (DC Carbs) 3310-1 carb I'm trying out has a PV in the front and blocked in the rear. It is not the .025 over bore version and had a nice fuel curve. Of course the jetting is not square F to B , but the fuel flow- A/F ratios look good. Up to now I've always run a std bore # 4779 750 by Da Vinvci. I'm not a big fan of PV's but this is the way he sent it and I'm going to try it that way. It does stay clean when idling and at low RPM.
Adger Smith (Former SS) |
