Old 03-27-2011, 05:08 PM   #1
FED 387
Liked 333 Times in 180 Posts
Default alan roerich or Adger smith ????
Guys what is the name of that kinda lite greenish colored epoxy used to reshape and fill voids/crevices etc in intake manifolds---cannot think of it to save my life???? Thanx Comp
Old 03-27-2011, 05:48 PM   #2
bubski
Liked 165 Times in 60 Posts
Default Re: alan roerich or Adger smith ????
788 splashzone compound ?
bubski is offline   Reply With Quote
Old 03-27-2011, 06:00 PM   #3
Ed Wright
Ed Wright's Avatar
I believe that's it!
Ed Wright 4156 SS/JA
Old 03-27-2011, 06:16 PM   #4
FED 387
Ya its the right greenish color I thout that permatex or somebody like that made but maybe I'm wrong--- thanx for the info will check into it in the AM---comp
Old 03-27-2011, 06:46 PM   #5
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
My son calls it the green death!!!!! Never breath that stuff when using it. I have some in my trailer. He has never told me the actual name of it.
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 03-27-2011, 10:40 PM   #6
Adger Smith
Liked 880 Times in 311 Posts
Dick,
Google: Z-spar Slash Zone Epoxy
Nice link about it on speed Talk. some good info:
http://speedtalk.com/forum/viewtopic.php?t=327
That link may only open for members. This is what one poster said:
Darin Morgan ยป Mon Sep 13, 2004 5:21 am
A-788 Splash Zone or Kop-Koat which ever name you prefer, is the ONLY epoxy I have ever seen that will stand up to the rigors of racing. If you use it with Alcohol you have to seal it with a clear coat paint in order to seal it off. You can use clear Acrylic or Emron clear coat. After you shape the epoxy to what you want, wash the head, dry it and clean it with Acetone. Then heat it up to 150 degrees and apply the Acrylic clear coat over the top of it and make sure to get the edges. Don't be shy with the stuff. Let it dry for 12 to 24 hours.
All epoxies will break down with Alcohol. Its just to corrosive. This procedure will make it last ten time longer.
Hope I didn't break any forum rules and the info helps.............................
Adger Smith (Former SS)
Old 03-27-2011, 10:58 PM   #7
FED 387
Thanx Adger---I want to use it to fill in some of the areas inside my sheet metal intake manifold along the welds and to eliminate some of the corners and smooth around the edges of the plenum and runner opening transition areas. Have you ever used it???Do you need to scruff up the surface area to get better adhesion between the epoxy and the aluminum??? Any hints will be most helpful---Thanx Comp
Old 03-28-2011, 12:25 AM   #8
Adger Smith
Mix it in small amounts. Mix well on a smooth dry surface. Just enough to do what you want to do. If it is mixing too dry add a little water. I'm saying "a little"! Keep your fingers wet. I keep a small cup full of water handy for my application finger. A Rough surface helps and wet it before you press in the first layer. You can slick the finish by wetting the finished surface and blend the edges by keeping them wet. Let dry 24 hours The wetter you use it the longer it takes to dry.
Good luck.
You would be surprised at what I've used this stuff for. Would you believe even a plumbing reapir at home?
