Old 03-28-2011, 01:53 PM   #1
FSA1673
Liked 12 Times in 6 Posts
Default Pontiac Head Flow - 197 Casting
What intake head flow at 0.425 lift would one expect from a properly prepared legal stocker 197 casting pontiac head. Engine is 455/335 hp combo with all the normal stocker stuff.
I understand that peak flow is not the wole equation but I assume you need a certain amount of peak flow to develop a certain amount of peak hp.
PM me if you do not wish to post. All information would be much appreciated.
Scott Underhill.
FSA1673 is offline   Reply With Quote
Old 03-31-2011, 11:16 AM   #2
FSA1673
Default Re: Pontiac Head Flow - 197 Casting
My heads flowed 230 cfm at 28" max lift. On the dyno I made a peak power of 470 hp at 5250.
Just wondering if my head flow is holding the peak power back?
Old 03-31-2011, 12:22 PM   #3
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
How was the torque curve?
Old 03-31-2011, 12:52 PM   #4
FSA1673
Torque curve is fairly flat, 510ft-lbs at 4500 to 470 ft-lbs at peak power. Converter stall speed is 4500.
